Td05hr-16g6c-10.5t
I have been doing a lot of reading on the stock evo IX turbo what I can't seem to find is if there is anymore boost to be made with the out of the stock turbo. I'm not talking about the G463, just the turbo. I've read that the turbo runs at about 20ish psi and drops a little lower at redline. I'm thinking along the lines of a wastegate actuator along with an aftermarket boost controller. If done proper how much psi could I squeeze out of that turbo. I'm not looking for anything insane, I would just like about 5 psi more and if possible retain more boost until redline. I'm looking for someone that has Actually done this before. Thanks for the info.
Re: Td05hr-16g6c-10.5t
you could do about 24 safely but it wont hold much more than that
MODS , 2g pistons, cyclone intake manifold, ported 1g head, 60mm tb, greddy type s bov, apex-i n1 exhaust , ngk spark plugs, 3 angle valve job, autometer boost/vac, autometer air/fuel ,autometer oil pressure ,cross drilled rotors ,turbonetics boost controller ,air filter ,remove dump tube, 14b turbo and the ac still doesn't work and its been almost 3 years |
