Old 12-21-2006, 04:12 PM
CALPC89 CALPC89 is offline
tire buckling
well recently i had an inner tie rod replaced and after a week my tire started to buckle. i took it back to the shop and had them look at their bad work and they told me that it was due to my caster, but the the caster cannot be adjusted on a 3000GT. is this true or do they not know what they are talking about? if it is true then what can i do to fix the problem. thanks
Old 12-21-2006, 05:45 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: tire buckling
They probably never put it back in alignment and now the toe is porbly now off.
Old 12-26-2006, 04:58 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: tire buckling
i agree.
there is not caster adjustment for the 3000GT/Stealth. only camber and toe. that shop either doesn't know what they are talking about, or are confused between caster and camber, which means they really don't know what they are talking about.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
