| Tips and Maintenance Post helpful tips, maintenance guides and R&R procedures here (for both Pontiac Grand Prix and Oldsmobile Intrigue) |
Fuel Filter Location and Replacement '97-'03
Here is a procedure which shows the location of the fuel filter in a '97-'03 Grand Prix, all models and the replacement procedure.
Click here Another way to relieve fuel pressure is to remove the fuel pump fuse located in the engine compartment fuse box while engine is running and let the engine die. It is highly recommended to use an AC Delco fuel filter, GF578.
Re: Fuel Filter Location and Replacement '97-'03
From a safety standpoint, I question this procedure that is referred to. The use of a metallic screwdriver on the schrader valve is the first concern. If that screwdriver slips and causes a spark while gas vapors are escaping, there is a good possibility of combustion.
Since GM designed this system wth metallic nuts in what appears to be a haphazard manner, shouldn't brass wrenches or some other non-spark-producing tools be used instead of the pictured wrenches? In my opion, the illustrated procedure fails from a safety standpoint. I've done this on a 98 Dodge Grand Caravan and the step by step rules from the AUTOZONE repair guide is much more explicit about safety and Chrysler did a much better job of making the procedure safer in the first place by using the plastic "quick connects". |
For the extremely safety conscious DIY'er there are alternative methods to relieve fuel pressure pointed out such as pulling the fuel pump fuse or using a fuel pressure tester that has a purge valve like the Actron model below. The procedure stands and will remain posted. It has been around for several years. If you have a problem with it contact the people at PFYC.com. ![]()
'08 Pontiac Grand Prix GXP (Dark Slate Metallic) - LS4 5.3L V8 '02 Oldsmobile Alero GL2 - LA1 3400 V6 '99 Buick Regal LS - L36 Series II 3800 V6 '03 Honda CR250R MX - 2 Stroke 250cc '97 Pontiac Grand Prix GTP - L67 Series II 3800 V6 Supercharged (Sold) Timeslip 08/12/06 AF Community Guidelines Last edited by BNaylor; 06-27-2007 at 09:16 AM. |
why doesnt the link work anymore? I was going to do this on my gtp, but would like info on it first. Thanks
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
Link works for me. ![]() http://www.pfyc.com/supportfiles/gasfilter/
there it goes, im sorry bnaylor. now i feel like a dumbass. Thank you!
The link now appears to be be going to the home page of the site. Does anyone have this info saved? Thanks.
No. PFYC redesigned their web site so the link no longer works nor is the procedure available. Just make a post at the regular part of the forum if you need help or do a search of the forum using key words "filter" and "fuel".
