Old 12-21-2006, 09:35 AM
Cbierniat's Avatar
Cbierniat Cbierniat is offline
Motor Mounts
How hard are they to replace... and has anyone ever done them? 99GTp
Old 12-21-2006, 10:55 AM
MVGTP86 MVGTP86 is offline
Re: Motor Mounts
Is it your front motor mounts?....If so they are easy....First turn your motor mounts and see if that helps. To do this take the bolt that runs through the middle of the rubbermotormount tighten it all the way(after youve removed the y-dogbone) and turn the bolt forward until the motormount rotates 90* in its slot, soak it w/ wd-40 if its not turning very well. The reason to do this is because if you notice there is gaps in the front and back of the motormounts that will cause the engine to move more than it should, by rotating the motormounts it makes them a lot stiffer. If you still need new ones after that get some stiffer motormounts from zzp..It hepls alot and keeps your tranny happy.
Here is a link on how to change the motormounts if you purchase the zzp polymounts. http://tacgp.clubgp.com/custom_mods/zzp/index.html
2003 GTP - Brand New L67 crate engine, K&N FWI, Ported TB, 3.4 s/c pulley, Walbro 340 fuel pump, 180* T-stat, 1.9's, PEM'S, ZZP 3" Down Pipe, ZZP 1.0 PCM, gutted cat, u/bend - resonator delete, magnaflow mufflers and tips.
Old 12-21-2006, 01:57 PM
Cbierniat's Avatar
Re: Motor Mounts
all i know is my motor jumps a lot and that when i get on it hard sometimes it pops...when putting it in reverse and giving it gas it also pops...and when i get on it in drive it kinda shudders a bit.
