Go Back   Automotive Forums Car Chat > Dodge > General Discussion
Old 12-20-2006, 10:21 PM
6speed's Avatar
6speed 6speed is offline
91ish dodge aries cd player
there is a wiring harness going to a panasonic head unit; out of the harness comes red & yellow for power, but no black for ground. coming from the car wiring there was a black with white line going to a blank slot on the wiring harness, so i moved the dimmer wire from its slot in the wiring harness over to the correct slot to use it as the ground. wired it up, cd player went on, everything was great...til i found the dash lights didnt work. so i unplug the cd player harness clip, still no dash lights. i connect the orange dimmer wire in the wiring harness (now back in its original slot) to the red 12v power source, dash lights go on; but they stay on until the key is removed even with the headlights turned out. after fiddling with some more wires ive found no combination that will allow the dash lights to get power again and the cd player to work, im totally stumped...please help
07 jeep cherokee srt8
99 saleen s281
05 cbr 1000rr
Old 12-22-2006, 11:56 AM
AWP9521 AWP9521 is offline
Re: 91ish dodge aries cd player
Check your "Instrument Lamps" Fuse and make sure it is not blown.
Originally Posted by AWP9521 - 02/16/2005
Sure sex is a thrill too, but your modified car will never tell you
"Sorry honey, I just don't feel like it tonight" it will always be in
the garage silently waiting for you to hop in so it can thrill you
some more, that is unless you break it. At least they're easier
to repair and get the thrill back than a pissed off girlfriend.
