| Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums. |
Cutlass Ciera 3.3 stop running
My cutlass with a 3.3 liter is giving me some problems...
I just replaced the fuel pump, relay, and fuel fitler because the car would stop running after 5 minutes of driving and there was low pressure in the vavle. I fixed that stuff now when i go to start the car it fires up for 1 second and tries to stay running but cuts off and pops in the intake. What could cause this? |
Re: Cutlass Ciera 3.3 stop running
Welcome to AF!!
There could be a lot of things that cause the car to stall like this. You need to do a systematic check of all the systems. The fuel system looks pretty good based on what you stated although you may want to replace the fuel pressure regulator before doing anything else. It may be malfunctioning and is causing a drop in fuel pressure that causes the car to stall. Other items are the ignition module, crank position sensor, cam position sensor and etc. |
the car looks like the fuel pressure regulator was messed with before(it is a different style regulator than most of the other 3.3s at the junk yard) and the rubber hose has been replaced.
also after the car fires up and tries to run for a few seconds at the most... the fuel pressure valve has low pressure(but once primed it goes up again). could this be a sign of a bad FPR? Last edited by westside95351; 12-21-2006 at 02:16 PM. |
does any fuel get in your air breather have u noticed?
eh my dad just had the same problem with his 88 new yorker so after spendin 360 $ on parts we didnt need yes u2 r right it was the FPR after all ...Ran us161 bucks but solved the probleme so 520$ to solve a 161 $ problem lol but we replaced the map sensor first .temp sensor fuel relay plugs wires cap figures it was the last thing we thought lol but ya it wasint sendin the fuel back to the tank just suckin at all threw the motor lol well gl eh BUD
