Old 12-20-2006, 06:58 PM
trigger_y2000 trigger_y2000 is offline
Battery died-now no radio
The lights were left on in my 2002 Taurus.It was jump started and now the radio doesnt work.There is nothing displayed on the radio at all.This is the only thing I can find that doesnt work.I checked fuse #27 and it appears ok.as nothing else appears to not be working.Any help would be appreciated.Also if it makes any difference it has the 6 cd changer option
Old 12-20-2006, 07:24 PM
dddcccmack dddcccmack is offline
Re: Battery died-now no radio
hummm some newer cars have to reset a radio code if you have power failer. Look in your owners manuel or call ford. if thats it youll need the code . . it should be in the owners mauel . . .if its not there youll have to beg the dealer to give it to you or pay him $$$
Old 12-20-2006, 07:41 PM
stv840 stv840 is offline
ford original radios don't have radio codes
Ck the fuses in the battery junction box fuses f101 (60A) f107 (40A) f117(20A) and f124 (5A)
Let me Know what you find becase if it is more than a fuse the diagnostic is lengthy but my system shows to ck thouse fuses first
Old 12-24-2006, 05:17 PM
Sorry its taken so long to get back.All fuses check ok.26 and 27 under the dash and all in the battery box.Still the radio is the only thing we can find that is not working.
Old 12-24-2006, 07:20 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Some factory (and most aftermarket) decks have a fuse on the rear of the deck, near the connectors. I haven't had the radio out of a 2002 to know if it has a fuse on the headunit, but it may be worth checking.
Were the jumper cables hooked up properly, or is there a chance they may have temporarily shorted or been connected with reverse polarity even momentarily? A regular jump start should not cause a fuse to blow. However, if you attempted to start the car with a VERY dead battery with the radio on, the fuse rating may have been exceeded due to the radio power requirements, and that could have caused the fuse to blow....
I assume you did attempt to power on the radio (although I think the clock would normally be displayed, even with the radio off).
-Rod
Old 12-30-2006, 05:36 AM
1955Joe 1955Joe is offline
On my 2003 Taurus when nothing on the radio (no 6 cd changer) would work it was because a rodent had eaten the wires in the trunk where the "radio" really is, hidden in the trunk on the left outer wall.
Old 01-02-2007, 11:38 AM
All it took was to unhook the ground from the battery for 10 sec.Doesnt make sense as the battery was dead but glad it worked.
Old 01-02-2007, 02:38 PM
shorod's Avatar
SHO No Mo
Interesting. Thank you for the follow-up post!
-Rod
