Old 12-20-2006, 06:32 PM
ellusion ellusion is offline
Weird starting issues
My car can start everytime but in certain situations the car will crank for about 2 seconds and then start, compared to its usual half-second crank-n-start.
Here is what i've noticed:
-Car starts normally every morning or when it has been parked for more than 9hrs.
-Car will start normally if it has only been parked for under 10 mins.
-HOWEVER, car will need to be cranked for at least 2 seconds (and sounds real weak) when the car has been parked between 10mins and 9hrs.
SO why is it that it starts withing 10mins of being parked, AND afters 9hrs of rest but not in between?? DOes it have to do with fuel lines or pressure in fuel system??
Anyone have any idea????
Old 12-20-2006, 08:31 PM
Igovert500's Avatar
blue + red light magnet
Re: Weird starting issues
Hm, that time thing is the only thing that sounds a bit odd. I would suggest just inspecting the ground wires on your starter. It could be as simple as that. I can't really explain the 10mins-9 hours thing, not sure anybody else will be able to either. Mine is kinda intermittant. Sometimes it cranks right over, sometimes it takes 2 seconds as well. I'm 95% sure its just hte wires on the starter in my case, I just need to clean the terminals up a bit.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 12-20-2006, 09:16 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Well the reason it starts right up within 10 minutes after shutting it off is because the ecu still stores the crank position sensor signal's last position until then, then it gets erased and has to crank a full revolution to find the position of the crank again.
The reason it starts up after 9 hours is because the fuel vapors in your fuel system settle in the cylinders over that time and when you crank it over, it ignites the built-up fuel causing it to start-up more easily.
Now is any of that true? I don't know, but it sounded like it could be. As long as it starts I wouldn't worry about it. ;D
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 12-21-2006, 03:07 AM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
when was the last time you changed your fuel filter?
Old 12-21-2006, 05:41 AM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
Old 12-21-2006, 06:42 PM
Fuel filter was replaced 2 months ago.
so there is nothing else i can do to improve it??
Old 12-21-2006, 07:56 PM
Igovert500's Avatar
clean/replace the terminals and or wires
could also clean the terminals of hte battery, check your spark plugs. Etc...
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 12-22-2006, 05:19 PM
i'll give them a try. cheers
