Old 12-20-2006, 03:57 PM
chevyguy777 chevyguy777 is offline
Eratic idle
My 2000 5.7l k3500 has an idle issue. It starts and runs fine until the engine is warm. Then the idle is eratic. It seems worse when the truck is in gear. I shift to neutral and it seems to smooth right out. The problem seems to be magnified in reverse. I can hardly keep the thing running while backing up. So far no codes. I have cleaned out the IAC passages and no difference. I tried to clean the the TB with the proper cleaner but the truck will not run with the air box off. Should i take it in and get the fuel system cleaned? Any help on this problem will be greatly appreciated.
Old 12-20-2006, 04:40 PM
tom3 tom3 is offline
Re: Eratic idle
Is it only at idle? Any roughness while accelerating on the road? My first guess was bad spark plug wires, or a bad spark plug, but you should notice it off idle under some load too.
Old 12-21-2006, 11:13 AM
Re: Eratic idle
Thanks for the response. If i let it idle rough at a stop light it will run a little rough under load on acceleration, but if i shift to neutral then to drive when the light changes its fine. I have replaced the plugs and wires with delco parts. Could it be that the egr valve is not working properly? Or maybe the maf sensor?
Thanks again
Mark
Old 12-21-2006, 08:03 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Re: Eratic idle
Is that like Eric Idle?
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 12-22-2006, 01:51 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
Re: Eratic idle
My truck did this and it was a clogged fuel filter/fuel pressure regulator. May want to check that too.
*Under Construction - New sig to debut*
Old 12-27-2006, 12:39 PM
Re: Eratic idle
Thanks i'll change the fuel presseure reg and filter. Hopefully that makes a difference.
Thanks again
Mark
