Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 12-20-2006, 12:14 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Fuel Pump rewire for 2g awd
Ok I got everything i needed to do the fuel pump rewire on my gsx today. On the website i was reading from it was for a fwd. It's not till i got everything apart that i found that my wiring and the wiring from the instructions were different. http://www.raktron.com/fuel/rewire5.html Mine has a few more wires. I looked everywhere for instructions for a 2g awd and came up with nothing. Im pretty sure the thick black wire is ground, but when i checked the black w/blue stripe wire for voltage i got .78V, not even a full volt. I read somewhere that said it should be 11V before the rewire. I did check the voltage with the car running too. My question is which wires are the ones that need to be cut, and on the relay, which terminal does the positive from the battery go? Every 1g directions i read said it goes to the 30, but that one with the 2g said to it goes on 87. If anybody has some advice for me i would really appreciate it. Thanks
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 12-20-2006, 12:51 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: Fuel Pump rewire for 2g awd
I am Bender. Please insert girder!
http://www.dsmtuners.com/forums/showthread.php?t=96412
Dsm tuners has spoken.
1991 GSX 2.3 Stroker
Old 12-20-2006, 04:34 PM
Im not sure i trust what hes saying he says hook up ground to 86 Ground, but on the diagram that came with the relay it says 85 is ground and 86 is the on/off switch and does it matter which way u hook up the 12V in and 12V out because i see a few people doing it both ways. As long as it works i guess it doesnt matter
94 Talon 1.8L-SOLD
Old 12-20-2006, 09:25 PM
defiancy's Avatar
Well I would do what it says there, and if it works great. (Which is should) If it doesn't just use another.
The wiring of the relay should be the same for FWD and AWD, just as long as you know what wires you need to tap into on the harness.
Old 12-21-2006, 03:17 PM
Well i got it rewired and it works fine, with constant 13.8 Volts at all times. I used http://www.raktron.com/fuel/rewire5.html for the wiring instructions for the relay. I was just thrown off by all the other yellow wires, which go to the fuel gauge etc. So it is the thick black wire for ground, and the black and blue wire for power. Hopefully itll help somebody in the future.
94 Talon 1.8L-SOLD
Old 12-21-2006, 03:32 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
I'm glad you got things figured out.. Maybe you could draw up a little diagram for those who actually search for answers and attach it to this thread.
Happy Holidays. Scott
DSM geek
Old 12-21-2006, 04:37 PM
Please excuse the shitty paint job but it still gets the point accross. Remember when u cut the black w/blue stripe wire the part still attatched to the connector goes to terminal 30 and the left over goes to terminal 86. The left over ground isnt used anymore. The wire going from the battery to the relay i used 10 gauge wire. The ground connected to the chassis i used 10 gauge and the wire from the relay to the fuel pump connector ground wire i used 14 gauge. Hopefully thats not confusing
94 Talon 1.8L-SOLD
