Go Back   Automotive Forums Car Chat > Chrysler > Sebring | Sebring Coupe | Convertible
Old 12-20-2006, 09:36 AM
Mac2002 Mac2002 is offline
Spongy brakes
My 1998 Sebring Convertible w/ ABS has spongy brakes. I have bled them a couple of times using the pump and squirt method with no improvement. Is there something special I have to do with the ABS system to do a proper bleeding?
Thanx
Old 12-20-2006, 10:31 PM
Jim-Tazmik Jim-Tazmik is offline
Send a message via AIM to Jim-Tazmik
Re: Spongy brakes
ABS brakes sometimes need to be power-bled with a certain electronic tool. Not sure what it is for Chrysler but I know the Ford tool. Sorry I couldn't be of more help.
4 out of 3 people have trouble with math...
Old 12-21-2006, 08:11 PM
stv840 stv840 is offline
Re: Spongy brakes
I don't think you need a scan tool to operate the abs unit you simply bleed from the wheels to bleed the systom through if you put a master cylinder on you will have to bleed the master first the bleeding procedure is to gravity bleed the RR wheel first followed by the LF then the LR Then the RF
Old 12-22-2006, 11:10 AM
Re: Spongy brakes
Gravity bleed, eh? I'll give it a try, in the correct order. Thanx
