Max Offset
Hey, I know its been awhile since I posted I just needed help with a quick question.. Is 20+ offset to muc for a 92 camaro and what is the max offset?
![]() http://www.cardomain.com/ride/631458 _______________ 92 Camaro V8 TBI 305 with Dynomax 3" Catback Exhaust, ASCD Iroc Turbo Hood, Goodyear Triple Tread Tires, K&N Open Element, Cat Delete, WonderBar Steering Brace, 160 Thermostat |
Re: Max Offset
you might call a tire and wheel company that deals with this sort of stuff on a daily basis.
2008 G8 GT ~ 2004 Silverado LT ~ 1998 z-28
Tuned By TJ Wong - Wong's Performance Engineering ![]() |
Re: Max Offset
the maximum offset depends on the width of the wheel...
http://www.chevyhiperformance.com/te...ro_wide_tires/ http://www.chevyhiperformance.com/te...es/index3.html this will give you a general idea. but like i said, the max offset you can use depends on the width of the wheel you are looking at. in general, forget about wheels wider than 9.5" in the front unless you dont want to turn your steering all the way. my 9.5s still rub at max turn.
90 Camaro RS V6 - swapped to V8 -350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft ESTIMATED 360-420 hp 380-430lb/ft torque
