Old 12-19-2006, 07:30 PM
Mudduckjeep Mudduckjeep is offline
Question Trans shifting to Fast, No down shft
I have a 1990 Cherokee it shifts good but to fast no mater how far you push the gas . It will not down shift (like passing gear) . You can shift it by hand and it shifts good and hard. I have only had it for about 2 weeks now . Still trying to get the bugs out of it . Thanks for the help
Old 12-20-2006, 12:01 AM
GregA's Avatar
GregA GregA is offline
Re: Trans shifting to Fast, No down shft
Hey Mud Duck - Welcome to the forum!
If your Jeep is like my '92, there is a cable that runs between the throttle body lever and down to the transmission. I think its called the TV cable (I don't know what that means).
Anyway, there is an adjustment procedure that might help. I would suggest you get a service manual to get the rest of the bugs out.
Here is the procedure for my Jeep:
THROTTLE CABLE ADJUSTMENT
With ignition off, fully retract cable plunger. Press cable button down and push cable plunger inward. Rotate throttle lever to wide open throttle position. Cable will ratchet to correct position. Release throttle lever. Cable is now adjusted.
I would also look into testing the Throttle Position Sensor.
Take Care,
Greg A.
2001 Chevy Venture w/some "enhancements" ~ 105K Miles (Dec. 2010)
1992 Jeep Cherokee Laredo, 4.0L, Automatic ~ 155K Miles (Dec 2010)
Old 12-20-2006, 09:20 PM
Thanks . I tryed it the way you said but no luck . I have a hanes book it said the same thing . Thanks for the help. I called Dodge they said bring it in and for $85 they would tell me what was wrong with it.
Old 12-21-2006, 12:21 AM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Cool Re: Trans shifting to Fast, No down shft
IMO...go to an automatic transmission specialty shop...if you have to go to a shop about the AW4 transmission.
Old 12-21-2006, 11:53 AM
citizen@large's Avatar
citizen@large citizen@large is offline
also, do a search on here for 'TPS' , aka- 'Throttle position sensor' , and 'FSM' , - 'Factory service manual'
I had the very same issue with my '89, and it was the TPS being out of specs. This only required the use of a volt-meter and a torx bit. (forget what size at this point, srry)...
I had tried adjusting the TV (throttle valve) cable many times thinking that was the problem, but alas, it was the TPS all day long...
PS- make sure you've got the proper fluid level in the tranny..
Old 12-21-2006, 04:13 PM
Saudade's Avatar
Saudade Saudade is offline
x 2 here. My '88 had a similar problem along with "hunting" between gears while driving at 45mph. Turns out mine was the TPS as well.
Old 12-21-2006, 07:08 PM
In addition to my above diagnosis, here's a link to a good page that covers several of the troublesome sensors on the Cherokee:
http://www.lunghd.com/Tech_Articles/...iagnostics.htm
Old 01-12-2007, 07:30 PM
Found problem the tps was not working . The guy I got it from must have taken it off (TPS) for something and did not put it back right . It works I looking for 5.0 mustangs now OK maybe a K5 Thanks for help. Kenny
Old 01-14-2007, 06:04 PM
Hey, your welcome. Thankyou for the update on the solution, it really helps those searching for the answer!
