| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
oil leak!!
Im not to sure on where I should put this thread. its either Problem Diagnosis or Performance. sorry if I picked the wrong forum.
anyways, I got the 2g install kit from turbochargers.com when I did my turbo upgrade. the problem is that the turbo oil return is leaking. it made of rubber and mesh like the 2g stock intake tube. the stock oil return is too long. I tried to bend the flexible part but it was still too long. how do i fix it? thanks
1997 Eclipse GS-T Performance modification:-evo3 16g-K&N Intake-HKS SSQV b.o.v vented-2.5'' Dejon tool blow thru upper and lower-Dejon large smic-GM MAF-MAF Translator-HKS 3" Carbon Fiber Titanium TBE-stock fuel rail-Walbro 190 fuel pump-PE 650cc injectors-Accel Thundersport wires-NGK series 7 spark plugs-1g intake mani/head- Interior Modification:-Autometer Boost Gauge http://www.cardomain.com/id/xTeamRedLine23x |
Re: oil leak!!
Are you able to trim it up any?
Oh and for the record, this should be in Problem Diagnosis. I'll move it for you.
-Brian
Re: oil leak!!
thanks for moving it me teh correct forum. anyways, I did trim the return hose from the install kit because that was to long. it started to kink when i bolted it up. now it fits perfect. I guess this weekend I am going to have to looks under the car to see if all the bolt are tight.
Re: oil leak!!
If not, then you may want to use some rtv and make yourself a new gasket for it...
-Brian
