Old 12-19-2006, 05:58 PM
fariekisses fariekisses is offline
steering wheel locked
i have a 97 grand prix and the steering wheel is lock so i can not start my car can someone help
Old 12-19-2006, 06:34 PM
MVGTP86 MVGTP86 is offline
Re: steering wheel locked
Make sure your shifter is all the way in park. Underneath your key/ignition there is a rubber piece, pop that out. There is a button you can push in on somewhere to unlock the steering wheel. I think the problem may be there is a solenoid that goes bad and causes this to happen. I have had several friends w/ GP's that have had to get it replaced...someone that has delt w/ this problem could probably help you out more though and know exactly what to do. I'll try to find a write-up ive seen for this on another forum and post it up for you.
2003 GTP - Brand New L67 crate engine, K&N FWI, Ported TB, 3.4 s/c pulley, Walbro 340 fuel pump, 180* T-stat, 1.9's, PEM'S, ZZP 3" Down Pipe, ZZP 1.0 PCM, gutted cat, u/bend - resonator delete, magnaflow mufflers and tips.
