Old 12-19-2006, 05:44 PM
Laoboiracer14 Laoboiracer14 is offline
really new to car audio. plz help
I need help...i tried to fix my stereo..so far i hooked up everything..the power cable to the amp...speaker wires to the sub..i bridge it also..im running a 600 watt kenwood amp and 2 MTX subs. theres a fuse on the power cable and i changed it and when i turn on my car the fuse blows and the amp and subs dont work...i need help on what to do...should i buy a new power cable?
Old 12-19-2006, 05:49 PM
sickcallawayc12's Avatar
sickcallawayc12 sickcallawayc12 is offline
Re: really new to car audio. plz help
sounds like the power cable and/or fuse can't handle that much power. just a guess though.
1998 Chevrolet Blazer LT (95% stock)
Pioneer AVH-P7500 DVD receiver
12" Alpine Type-R in a sealed box
PIAA Super Plasmas GT-X bulbs
PIAA Xtreme White bulbs
K & N drop-in filter
"Melo" and "AI". Enough said.
Old 12-19-2006, 07:03 PM
Should i just get a new power cable then?
Old 12-20-2006, 01:05 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
sounds like you either .....
1) have something connected wrong
2) have a bad amp
3) are using the wrong sized fuse
Old 12-20-2006, 02:01 PM
the fuse im using is size 30..the green color fuse.. how can i tell if i have a bad amp?...what connections i made wrong?
Old 12-20-2006, 03:46 PM
check the package of the amp kit you bought and make sure you are using the right type of fuse (nothing that is less or exceeding what you need) and check to make sure your amp kit is designed to handle the watts your amp is delivering. tell us how your system is connected currently and the audio gurus can tell you if something is amiss (i probably can't).
Old 12-21-2006, 08:37 AM
PlayStation3 PlayStation3 is offline
do you mean a 30 amp fuse? cause you need around a 45 amp one if you do the calcalations (sp) 600 watts of the amp divided by a consent 14.4 volts
Old 12-21-2006, 01:43 PM
where can i get a 45amp fuse at?
Old 12-21-2006, 01:52 PM
well i put in the deck. i wired the harness.. i conected to RCA cables to the amp. i ran the power cable from the battery to the amp. i bridge the subs.. i ran the remote wire from the amp to the deck. i grounded the amp to a bolt that holds the latch to close the trunk. i checked all the fuses. only the power one blows.
Old 12-21-2006, 01:54 PM
bjboertje's Avatar
bjboertje bjboertje is offline
i don't think there is a 45 amp one, 40 amp is the biggest you can get in the (i forget what it is called) spade type, i think. check to make sure the power wire isn't touching anything or worn through, make sure speaker cables aren't shorted anywhere.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Rainbow CMX 265 front stage
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 12-22-2006, 04:48 PM
dbfreak147.5 dbfreak147.5 is offline
is the power wire running to the 12+ on the amp or is it ran to the ground, i maybe wrong but i try to help but if i am wrong sorry
2 Orion HCCA 10'S
2 AudioPipe 3k's
Adam Whitehead
Old 12-22-2006, 08:17 PM
Audio Guy
the green 30 amp fuse is called an ATC ....
Old 12-23-2006, 12:29 PM
well the power cable is split because at the end of the cable where it connects to the battery it has a fuse connector to it so the amp wont blow i guess. and its attatched to the power wire and shit. and is elctrical taped. so yea..
Old 12-24-2006, 08:10 PM
Audio Guy
that fuse near the battery is to protect the CAR, not the stereo stuff.
Old 12-25-2006, 12:29 AM
so i can take out that fuse thing?. and just run the power straight to the battery?
