Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 12-19-2006, 04:09 PM
jg09's Avatar
jg09 jg09 is offline
Rally Camry; am I truly crazy?
I'm planning on building up my 1988 Toyota Camry Wagon into a mildly built rally car. I'm going to fabricate 2.5" or 3" coil spacers, upgrade the steering for strength, trim the fenders, run a mildly bigger tire/wheel combo, fabricate a roll cage, remove the rear seats, put in racing seats and harnesses up front, and put in a fuel cell.
RIP: Colin McRae 1968-2007
Johnny McRae 2001-2007
Old 12-23-2006, 06:14 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Rally Camry; am I truly crazy?
Moved to Camry Forum
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 12-23-2006, 05:02 PM
xfeejayx's Avatar
xfeejayx xfeejayx is offline
you're going to have to do a lot more to the suspension than that. I'd imagine the wheel bearings getting destroyed, though i'm not sure. If you just want a camry that can kinda drive in the dirt, I guess that'll work. Not trying to rain on your parade, but I wouldn't call it a rally car.
Old 01-02-2007, 04:10 PM
jg09's Avatar
Also going to be done: Change out the suspension, get a decent strut/spring set, also going to change out the old rubber bushings and replace them with something stiffer, likely polyurethane, but that might be a bit hard to find for that car, a steel plate between the coilover and the strut tower to reinforce the strut towers, and a strut tower bar so I can stiffen up the front.
