Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 12-19-2006, 03:45 PM
brentandbecky brentandbecky is offline
Intermittent starting problems, 2002 Impala
Hello,
I am posting here on behalf of my girlfriend who owns a 2002 Chev Impala. Despite being an older model it only has about 45,000km on it and has regular oil changes. After the car has been running for a while, if we shut it off it usually has problems starting up again. We'd like to resolve this problem because we are worried that we could cause more damage to whatever the problem is, or get stuck some place bad.
To further describe the starting problem: If we are taking the car out after it has been sitting for several hours it will start no problem. If we go into a store or something, when we come back out and try to start it, it will not go. The panel lights all come on, but the engine does not make any attempt to start. Usually after fiddling with the gearshift and retrying to start it a bunch of times it will go, but it is scary every time.
What we have done so far: Recently we took the car into an independent auto mechanic who spent a day looking at it and could not figure out what the problem was (he was unable to reproduce it), so he recommended that we take it to the Chev dealership. The Chev dealership had our car for a week and did not keep us in the loop with what they were doing, only to tell us to bring it in when the problem was occuring. Since the problem doesn't seem to happen after the car has been sitting for a few hours, I don't think doing what they ask will help at all - only cost us more. So now I am turning to you, while wishing I had in the first place
On a slightly different note, after we got the car back, our command start no longer works. I'm also looking for suggestions on how to make sure it is connected or whatever if I can even do that without a shop. Not sure if it was a mechanic error or just bad luck, but either way we'd like to get it going again because it is freezing out!
As a former computer tech, I know how intermittent problems can be hard to troubleshoot, but usually have a process or some kind of idea as to what the problem is in advance. I'm hoping some of you car gurus will be able to offer some ideas and advice as to what is causing this starting issue. If any further information would be helpful, please let me know. I can also take pictures of any components in question if needed.
Thanks much in advance and Happy Holidays,
Brent and Becky
Old 12-19-2006, 04:28 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Intermittent starting problems, 2002 Impala
You need to check for voltage at the "s" terminal on the starter solenoid (when the key is in the start position) when the car doesn't start. If there is voltage there, the starter is bad. If there is no voltage there, then it's an ignition switch or neutral safety issue. This could also be caused by a faulty remote start module.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 12-19-2006, 04:37 PM
Thank you for the fast reply - would it be possible for you to explain to me where/what the "s" terminal on the starter solenoid is? Is it accessable to a car newb? As for the remote start module, is there any way I can troubleshoot that (maybe remove it?) myself or should I go back to the mechanic with these informations?
Thanks,
Brent and Becky
Old 12-20-2006, 06:53 AM
crazy Jim's Avatar
crazy Jim crazy Jim is offline
classic starter solenoid getting hot and not working, then after a bity it cools and works fine. Replace the starter solenoid...
Old 12-20-2006, 07:30 AM
richtazz's Avatar
There are two wire terminals on the starter solenoid, the large one where the battery cable connects, and a smaller one which is the "s" terminal (signal wire). The starter on your car is mounted in the front, and you should be able to access it while the starter is installed. You may have to jack the car up to gain clearance/access. Here is a link to AC-Delco's website picture of the starter for the 3.4 engine (3.8 is similar).
http://198.208.187.182/internet/View...umber=336-1931
