| Off-Topic Talk about anything other than cars. |
It's off topic, for another car. Better here than over there tho.
96 Mecurury Mistique. New plugs and new O2. When flooring the gas pedal, car stutters and almost dies. Sometimes does die. Plugs are gapped right. No CEL. Haven't driven it up but i will later. Going to clean air filter too (if hood opens. Latch was broken during the week). Please help. Thanks
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
Re: Friends Car Problem
What kind of plugs did you feed it? How is the fuel filter and fuel pressure? After market air filter? What engine? One has tsb on a pcm flash for that problem. Also unplug MAF sensor and see what it does.
I forgot to post the engine. It's a 4cylinder, I believe 2.0, DOHC. Automatic.
Plugs were from Autozone, I believe Bosche. We're going to try to pop the hood later on today.
The 2.0 l with a CD4E and certian calbrations need a pcm reflash for that problem. Have you dealer run your vin no. for a update reflash. Also go over fuel pressure and MAF sensor and check for good spark.
BOSCHE FTL...
do what he said and disconnect the MAF... if the car runs, but rough... then it will be that sensor... try swapping in another ECU... Has the car sat for a long time?
1991 Eagle Talon TSI - Broken Head removed, block broken, trans in hatch ![]() 1991 Eagle Talon TSI AWD- in pieces 3" exhaust, rebuilt bottom end Project: Assemble the Eagle is underway... and now with AWD 2003 Lancer Evo 1630hp/1593ft lb tq |
