Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-19-2006, 02:50 PM
carguy2779 carguy2779 is offline
motor swap
I have a 88 firebird tbi swaped the 305 with a 350. deleted the egr and evap system. starts and runs but craps out around 2g's. cant find the problem. any help?
Old 12-19-2006, 05:12 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: motor swap
Which knock sensor are using? Also, I think you need to swap the PROM chip for a 350 too?
Old 12-19-2006, 09:12 PM
SG007's Avatar
SG007 SG007 is offline
Send a message via AIM to SG007
Re: motor swap
If you're still using the computer it has to be updated. It still thinks you have the stock motor in there so it's freaking out. Been there. Not fun.
-2000 LS1 Z28-1979 Berlinetta*sold*-1992 RS 25th Anniv. 350*sold*-
Old 12-20-2006, 01:36 PM
Re: motor swap
im using the knock sensor that came off of the 305. yes the stock computer is in use. so in order to get this beast to quit pooring fuel im going to have to have a new chip burnt?
Old 12-20-2006, 02:14 PM
wrightz28's Avatar
Re: motor swap
You need the 350 knock sensor and PROM.
Old 12-20-2006, 02:21 PM
Re: motor swap
would i nedd the one off of thetpi or just a fuel injected 350? If i had a chip burned would it be the same thing?
Old 01-22-2007, 02:36 PM
Re: motor swap
Ok guys put the new 400 dollar little chip in and all was well until i put the exhaust on...its surging like a vaccum leak but no leaks i have used several cans of brake clean. But when i unplug the computer timing wire it quits freaking out and runs fine. No check engine lites either. any ideas?
Old 01-22-2007, 03:43 PM
wrightz28's Avatar
Re: motor swap
Did you have to reroute the O2 sensor? Make sure the sire didn't get burnt and is fully connected.
