Old 12-19-2006, 11:48 AM
orpheum13 orpheum13 is offline
Front Driveshaft
ok, in trying to solve a vibe problem, im looking into my front driveshaft. My
question is, while lying under the car and pushing up and down on the
shaft....should there be any play in the slip yoke( i think its the slip yoke?)
where the grease fitting is?
Pluto will always be a planet in my heart
Old 12-19-2006, 01:23 PM
Ray H Ray H is offline
Re: Front Driveshaft
There may be a little play, like maybe 1/8" of movement at the slipyoke.
pull the driveshaft off and drive. Thats a sure fire way of finding out if its a driveshaft related vibe. You dont even need to pull the whole driveshaft off, just unbolt it at the axle and tie it up out of the way. Dont put it in 4X4 if you choose to just tie it up.
Old 12-20-2006, 08:05 AM
thanks, i'll take it off soon as i get a chance and see how it goes. Another quick question...
The colar on the FDS where the grease fitting is, i can grab it and spin it around. Should i be able to do that...?
i'm trying to find someones cherokee so i can see how it is, but no luck so far.
thank you
Old 12-20-2006, 03:36 PM
thank you
Its ok if the collar spins. Im rebuilding a front driveshaft today. New Ujoints, regreasing the CV centering ball. Im going to use it for a rear DS when I lift my XJ. The collar spins on mine also. Ive never had that collar off before. Its a tight fit on the shaft but I think you can pull it off and seperate the DS. I'll let you know later. BTW, The FDS Im working on now has virtually no play in the slip yoke.
Old 12-21-2006, 09:08 AM
Thanks, my FDS has a significant amount of play...probably the problem...i'll check it out as soon as the holidays let me...busy time of the year for workin on the jeep...thanks for the input
Old 12-21-2006, 04:18 PM
I did some work on my FDS today. No luck getting that cap off though. I tried pulling, twisting, beating and it wouldnt budge. Maybe it doesnt come off? but I dont know whats holding it on.
