Heads from 5.7L on 5.3L?
I have found multiple posts where people have put heads for a 5.3L engine on a 5.7, but I was wondering if the reverse would also work. I have a friend who has a brand new set of 5.7L heads he can give me for free if they will work. I have a cracked head and therefore must replace, and was wondering if they will work properly, or have a different compression ratio, or any other issues I am not considering. Does anyone have any thoughts on this?
Thanks! |
Re: Heads from 5.7L on 5.3L?
If it's a Gen-III (LSx) 5.7, I don't see why it wouldn't work, although the combustion chamber might be a little larger leading to a lower compression ratio.
If that 5.7 is a Gen I or Gen II, forget it.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
I think you'd have a better chance of getting a Ford head to work.
![]() ![]() ![]() "When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson 2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster |
yeah if by a 5.3 you mean an old school 327 and by a 5.7 you mean an old school 350, then it would work, but if you mean the 5.7 old school 350 and the newer 5.3 whatever cubic inches it is, then theres no way in hell. maybe you have the 5.3 confused with a 5.0 old school 305?
i doubt that putting 305 heads on a 350 would really make any difference. In fact i bet it would hurt your performance since i bet the valve sizes are smaller for the 305 heads or something, i have always heard that the stock 305 heads were worthless |
Gen I/II 5.7 liter = 350 cid Gen III 5.7 liters = 346 cid 327 - gen I motor - 5.4 liters Gen III/LS 5.3 liter = 325 cid Gen I 305 = 5.0 liters
With the center cyls on the 5.7 having siamesed exhaust valves and the 5.3 not, then the cam shaft lobes would not jive with what the valves should be doing if you changed to the 5.7 heads. It isn't going to make it displace any more cubic inches so what would be the motivation for the swap anyway?
