Go Back   Automotive Forums Car Chat > Dodge > SRT4 > SRT4 Problem Diagnosis
Old 12-18-2006, 11:06 PM
srt_4driver srt_4driver is offline
bov?
i installed the mopar bov and it did not work its not on backwards and there is no leaks, i was told there are two types of springs for the stock bov is this true?
Old 12-19-2006, 06:42 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
Re: bov?
What do you mean it didn't work? Is the vacuum line still hooked up to it? Did you use a gasket? Are you positively sure it's facing the right direction?
There are two springs but it won't effect functionality of the surge valve, just when the the air releases and how much pressure it can hold, etc.
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 12-19-2006, 06:51 PM
Re: bov?
all vacuum lines are connected and it is facing the correct position, there is no vacum leaks, it just wont blow off like it should, and i was told there are two types of springs in the bov, this one has six coils.
Old 12-20-2006, 01:19 AM
TEXSRT4 TEXSRT4 is offline
Re: bov?
you installed it backwards, the center hole going 1/2 the way through goes towards the ground/front of the car or away from the turbo itself
Old 12-20-2006, 12:46 PM
Re: bov?
That is the way i have it and it does not work the gasket and the port are all on the right way and ive made sure plenty of times, there is vac. on the pink line the bov just does not go off.
Old 12-20-2006, 05:25 PM
Re: bov?
somthing went wrong on the install. uninstall it and try it again. i am assuming you still have your solinoids on the air box. follow the vacume lines and check the connections
