Old 12-18-2006, 10:57 PM
89civic_sedan 89civic_sedan is offline
Need some help
got a new distributor for my car and now it wont start up and the check engine light isnt even coming on...Need some help bad
Old 12-18-2006, 11:24 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Re: Need some help
Posting 4 times won't get you help any quicker than posting once. Were you not getting spark to begin with, before replacing your dizzy? Are you currently getting fuel? Is your "new" dizzy an aftermarket item or did you pull it from the yard? What car do you have and what motor?
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 12-18-2006, 11:52 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: Need some help
I took care of the reposts. Be a little more patient, if your browser messed up during the process, just wait a minute and check and see if it was posted before you hit the button again.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 12-19-2006, 03:00 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: Need some help
Are you getting spark?
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 12-19-2006, 09:48 AM
Re: Need some help
how can i tell?
Old 12-19-2006, 11:54 AM
Re: Need some help
how can i tell?
Pull off one of your spark plug wires and hold it up against a ground bolt on the valve cover. Have someone crank the car and you should be able to see a tiny spark flow through the end of the wire.
Old 12-19-2006, 12:07 PM
Re: Need some help
ok...and what do i do if i get no spark..
Old 12-19-2006, 12:08 PM
Re: Need some help
And the check engine light just came on and thre code 16 so what do i do with injectors...get new ones or clean them? and where are they at?
Old 12-19-2006, 12:14 PM
Re: Need some help
Nope i didnt get any spark out of any of the plugs. Now what do i do?
Old 12-19-2006, 05:28 PM
thefooshmeister thefooshmeister is offline
Send a message via AIM to thefooshmeister
Re: Need some help
lol your injectors are right below your fuel rail..go buy a haynes manual please..
98 Jetta GLX VR6-vroom vroom!!
91 CRX Si-R..busted..
Old 12-19-2006, 05:47 PM
bambam89lx's Avatar
AF - Advisor
Re: Need some help
Are you sure it was a code sixteen? one LONG blink and 6 QUICK blinks right? If you're not getting spark, try replacing the coil inside your distributor.
Old 12-19-2006, 10:21 PM
Re: Need some help
thats what i replaced today the coil and did the same thing..no spark
Old 12-20-2006, 03:41 AM
bambam89lx's Avatar
AF - Advisor
Re: Need some help
maybe the ignitor then, or a bad plug connection.
Old 12-20-2006, 02:51 PM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
Re: Need some help
its a long shot but make sure u got the right distributor for ur car..what motor do u have and whats the part number on the dist..
Old 12-20-2006, 05:41 PM
Re: Need some help
its the same distributor that ive had sense i got the car.. I just replaced the coil in it.
