Old 12-18-2006, 09:31 PM
Blownpiston Blownpiston is offline
Question pulling engine
1997 geo metro with 1.3 litre and automatic trans. Other than the direct instructions in haynes and chiltons books, whats BEST way to pull this motor? I know some of you have personal tricks and experience here that can help greatly. geozuki you around? Thanks a bunch men or women.
Old 12-19-2006, 12:32 AM
91Caprice9c1 91Caprice9c1 is offline
Re: pulling engine
With the 3 cylinders I don't mind pulling the engine or transmission independently from the other. However with the 4 cylinders I find it easiest to pull the engine and transmission as a unit. Remove the torque converter bolts while installed. Remove the head while installed. Than attach a crane to the head bolts, remove mounts and axles, lift out of car, then seperate afterwards. A little more prep time, but worth the relative hassle of the 4cylinders. Just my two cents.
-mechanicmatt
Old 12-19-2006, 07:46 AM
sbiddle sbiddle is offline
Re: pulling engine
I swapped out a motor this spring on my 1.3L automatic. I did not pull the transmission with the motor. Instead, I removed the crank pulley to gain room for shifting the motor away from the transmission. I left the intake and throttle body attached to the engine along with the exhaust manifold. A couple of the bellhousing fasteners are a PIA, but overall, not too bad of a job
Old 12-20-2006, 02:31 AM
Re: pulling engine
91caprice9c1 and sbiddle, GREAT TIPS guys. Thanks. I kinda thought there was better ways than strictly textbook.Job sounds easier already! Plan on jumpin in there this winter sometime.
