Old 12-18-2006, 06:10 PM
NScarpi NScarpi is offline
Unhappy Pulls to right
I have a 92 wagon. When I got it, it was in bad shape. I put a engine in it, both tie rod ends, struts,tires and wheels, new rotors and had the front end aligned.
It pulls to the right. Also the streering wheel is not centered, it is 1/4 turn to the left. The guy at the shop told me that to get it in alignment he had to unscrew the passenger side tie rod so far that he could not straighten the wheel any more. There wouldn't be enough threads to hold the tie rod to the inner tie rod safely. He also said he got everything within spec's, so I thought all was fine. It still pulled. OK so I figured the sub frame was out of alignment and I got under it and adjusted it. It wasn't out very much. No change. I also checked that the streering wheel was positioned in the center of travel, it was perfect. Before I did anything to it, it was pulling to the right alittle, but the steering wheel was 1/4 turn to the right. I checked the frame as best I could, there doesn't seem to be any damage, or signs of repair. I don't know what to do next. Has anybody out there run in to this problem before?
Thanks
Nick
Old 12-18-2006, 09:59 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Pulls to right
Any evidence that the car has been in an accident before? It seems very unlikely that a "straight" car would have a steering assembly so far off.
-Rod
Old 12-19-2006, 04:28 PM
Re: Pulls to right
That was one of the first things I thought of. The front door and fender on the passenger side are dented, but not bad enough to cause this. I checked the body underneath them and there's no sign of damage or distortion. It really doesn't make sense to me. I'm wondering if the person who had it before me moved the u-joint on the streering wheel shalf where it connects to the rack. That might explain part of the problem.
Thanks
Nick
Old 12-19-2006, 06:10 PM
Millermagic Millermagic is offline
Re: Pulls to right
I'm pretty sure whenever you replace tierods / tierod ends, you need to get the car aligned.
- Leather - Transmission Cooler - Gen III Tweeter Sails - Gen III Rocker Covers -
As you walk through the valley of RICE, you shall fear NO V-TEC, for torque is with thee!
Old 12-19-2006, 09:53 PM
shorod's Avatar
SHO No Mo
Re: Pulls to right
True, it is wise to have an alignment performed when a suspension or steering component is replaced, but if the car is straight, there should be more than enough threads on the adjustable parts to align the car AND have a straight steering wheel. Something on this car is not correct.
-Rod
Old 12-20-2006, 04:46 PM
Re: Pulls to right
I'm not sure if it has been in an accident I don't know the previous owners. It doesn't show any signs of major damage or distortion. That's what makes it so hard to figure. As much as it is off you would think that it would be easy to find some signs of damage.
Thanks
Nick
Old 12-20-2006, 06:46 PM
dddcccmack dddcccmack is offline
Re: Pulls to right
yes, if it pulls its a tire! also i dont buy the tie rod story your told, unless the frame is bent. tow in, tow out or on the mark either way the wheels are going find center line. switch tires and see if it pulls the other way
Old 12-21-2006, 11:50 AM
Re: Pulls to right
I not only rotated the tires I put different tires and rims on it. No change.
Nick
Old 12-21-2006, 02:54 PM
Re: Pulls to right
hummmm . . . did you jack up the front end and spin the wheels to see if there is any brake or bearing drag? If its the same try the same test after the brakes are HOT and Cold also whale the front ends up in the air, tap the pedle to see if the calipers is sticking.
Take a tap measure and accruetly measure and compare the distants between the front of the back tire and the back of the front tire. I would assume they should be the same (be sure tire presure is the same on all four) or no wait measure it from the rim serfice not the tire.
Are you compairing the pull on a perfict road(s)?
Old 12-23-2006, 05:13 AM
Huney1 Huney1 is offline
Re: Pulls to right
"yes, if it pulls its a tire! also i dont buy the tie rod story your told, unless the frame is bent." You already switched tires so doubt that's the problem.
"I checked the frame as best I could," No way you can check the frame with the same degree of precision a frame & body shop does. Take it to *another* good frame & body shop and explain what's going on and ask them to take a look-see to detect accident work and if there is have them check the frame because if it's bent you'll never get it to track straight. Doubtful a brake pad is dragging because it would get hot and you'd smell it. From what I see, about the only thing you haven't done is have the framed checked by a professional.
Costs $20. to run a car fax at www.carfax.com and it should show wrecks.
Old 12-23-2006, 01:03 PM
shorod's Avatar
SHO No Mo
Re: Pulls to right
I'm with Huney1 on this, take it to a body shop and have them check the unibody for structural damage and straightness.
Don't rely on a Carfax report since Carfax will only know as much as the insurance company knows. If an accident was not reported to the insurance company, it will likely not show up in Carfax. If the unibody is damaged, any accident repair work was probably not done professionally, and therefore an insurance company may not have been involved.
-Rod
Old 12-23-2006, 01:09 PM
Re: Pulls to right
you may or may not be as accuret as a alinment shop but if you think about how and what your doing to measure you will be within 1/16" -1/8". your not going to feel pull by off 1/8" (front to back) and if it's off by an obvious amount 1/2" or more which you are going to see right now, youll know this is most likely where the problem is or its been hit . . . point is its a cheep place to start.
profesional aliments are not as accuret as you think. I can do toe in toe out with a long adjustable rod and be within .025" which will change at the very next pot hole you hit.
Old 12-24-2006, 09:30 AM
shorod's Avatar
SHO No Mo
Re: Pulls to right
But there is more to a professional alignment than just toe measurements, more more than just toe can cause a pull. Professional alignment systems also measure caster (front and rear), camber (front and rear), thrust angle, and rear toe. You'll have a hard time getting all these measurements within factory specifications using a string or long bar. I'm not trying to say you can't get by doing this, if you are starting with a straight car. However, in this case, I think the owner would be best off to get the car checked by a professional.
At the very least, he'll find out that the car IS straight and can then focus his efforts on other options. And, he can apply your methods in the future and be reasonably certain the results will be reasonably accurate.
Besides, a professional alignment, if it the alignment is not off by much, will cost him less than a set of tires and hopefully prevent him from needing to replace tires prematurely.
-Rod
Old 12-24-2006, 09:47 AM
Re: Pulls to right
Well said Rod and thanks for the confirmation. I am by no means a frame and body man but used my old horse sense, i.e.; first things first.
Okey dokey then. To all the great folks that participate in and visit the forum;
From the LowCountry swamps of S Carolina where it's 53F going to 70F today,
A VERY MERRY CHRISTMAS TO EVERYONE AND WE WISH YOU HEALTH, PEACE, LOVE, HAPINESS AND PROSPERITY IN 2007 AND GOD BLESS THE USA!
Old 12-24-2006, 01:56 PM
Re: Pulls to right
I've had bad tires on my car from March - November. In that short amount of time the belts went bad in 1 or 2 of them and the car feather edged the inside of the right front tire. It pulls to the right.
I swapped on my winter tires and it doesn't pull to the right so bad or shake but it's still out of alignment.
