Old 09-20-2002, 09:53 AM
lscvii lscvii is offline
Ford AOD tool T80L-77003-A (gauge bar) thickness?
I am building a AOD Ford Transmission. Does anyone happen to know the thickness of the ( FORD, END-PLAY CHECKING TOOL ) part # T80L-77003-A . It appears that Ford included the thickness of the tool in the depth specifications. Without this information, it is next to impossible to set up the end clearance for the intermediate clutch and the clutch drum.
dc
Old 09-18-2005, 01:26 AM
Mark8denny's Avatar
Mark8denny Mark8denny is offline
Damn , I have been looking for this for hours , I am finishing up a trans tonight and hoped I would find it here , I have friends at the dealer and will post it if I can find it monday.
Old 09-18-2005, 07:39 AM
351wStang's Avatar
351wStang 351wStang is offline
Re: Ford AOD tool T80L-77003-A (gauge bar) thickness?
You are talking about a tool to reach down into the tranny to lift on the c;utches/frictions to check clearances correct? If so I've always use a metal coat hanger.
1969 Cougar
357w & TKO - 475hp
Old 09-18-2005, 01:14 PM
Mark8denny's Avatar
Guage bar
The tool is used as a straight edge and is set across the pump case mounting surface. You measure the distance down to the intermediate clutch plates and to the reverse clutch drum thrust face in order to select the selective steel (for the intermediate) and selective thrust washer (for endplay). Individual clutch packs can be measured with a feeler guage , The Ford tool is a square bar with the holes in it to use a depth micrometer.
Old 09-18-2005, 02:00 PM
Mark8denny's Avatar
Four score and seven years ago ...
Old 09-19-2005, 10:47 PM
Mark8denny's Avatar
I found out today , The tool is .700 " thick . Anyone can take the measurements now , even if you dont have the tool. Just take the ford spec and subtract .700 ". This will put your measurement to the pump mounting surface directly. You could use a straightedge then or whatever you have that is straight (make sure you measure to the bottom of whatever you use) The specs ford gives is to the top of the guage bar .700" above the pump mounting surface (thickness of the bar)
Old 09-19-2005, 10:52 PM
Mark8denny's Avatar
That mustang is fast ?
Where is that Mustang from ? I swear I saw it in a pep boys parking lot !
Old 09-19-2005, 11:29 PM
351wStang's Avatar
Was that supposed to be funny? I'm not getting into a flame war with you...Grow up junior.
1969 Cougar
357w & TKO - 475hp
Old 05-19-2013, 05:38 PM
rp2pierce rp2pierce is offline
Thank you Mark8denny, you saved me a lot of time and headache with that information on Ford tool. I thought I was loosing it at first.
4R55E Front End Play Check Gauge Bar T93T-77003-AH mrstubb Explorer | Explorer Sport Trac 0 06-13-2010 02:59 AM
Ford AOD rebuilt Transmission MercGMarq Cars/Parts for Sale/Exchange 0 09-27-2006 11:35 AM
AOD tool T80L-77003-A (gauge bar) thickness? lscvii Cougar 0 09-20-2002 09:57 AM
Ford T80L-77003-A (gauge bar) thickness? lscvii Thunderbird 0 09-19-2002 10:25 AM
