Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 12-18-2006, 04:06 PM
professional6 professional6 is offline
horn resistor
I need to know the location of the horn resistor
Old 12-18-2006, 06:23 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: horn resistor
Are you sure it has one?
Whats the problem or what is it doing or not doing?
YEAR AND ENGINE ANDS TRANS AND MILEAGE MIGHT HELP.
MT
Old 12-18-2006, 06:33 PM
Re: horn resistor
My heater and a/c blower won't work.put in a new motor still won' t blow. checked the resistor can't tell if it's good or bad. I read on the forum that before i buy a new one use the horn resistor or relay.
Old 12-18-2006, 07:43 PM
GregA's Avatar
GregA GregA is offline
Re: horn resistor
I think I understand - Blower Motor Resistor Pack!
There may be a main relay under the hood for the blower. I would look at the chart under the cover & see if you can swap it with the horn relay.
Otherwise, the blower motor resistor pack should be mounted near the fan, but you probably know that already.
Take Care,
Greg A.
2001 Chevy Venture w/some "enhancements" ~ 105K Miles (Dec. 2010)
1992 Jeep Cherokee Laredo, 4.0L, Automatic ~ 155K Miles (Dec 2010)
Old 12-19-2006, 06:37 PM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Re: horn resistor
Yeah..the resistor and relay are different things.
The resistor is the problem if the blower will blow on high but not low.
The relay could be the problem if the blower does not blow at all.
First check the fuse and then subsitute the horn relay for the blower relay.
On the later model like mine...the blower relay is behind the glove box and the horn relay is in the right hand kick panel. Covers and stuff need to be removed to get to them. The relays are cheap anyway...under 20 bucks..more like 15...
What year? recommend a manual...
Old 12-25-2006, 09:33 AM
MT-2500's Avatar
AF - Advisor
Re: horn resistor
thanks it was the relay. quess what? i went xmas shopping today and when i tried to start the jeep the key wouldn' turn at all. i think it's the switch, can i hot wire it if it's in park and still drive. ineed to get it home.
It looks like you are running a double post on this.
What is the deal?
Two post will get you two confusing answers.
http://www.automotiveforums.com/vbul...=596400&page=2
MT
Old 12-25-2006, 11:07 AM
AlohaBra's Avatar
Re: horn resistor
Hey MT-- I moved professional's thread and merged it....hopefully he can get his Jeep fixed and back home by xmas.
PS...just to clear things up...there is no horn resistor.
Closed Thread
