Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 12-18-2006, 03:56 PM
littlej61 littlej61 is offline
I need help installing a remote starter
I just got a remote starter and I'm having trouble getting to the ignition wire harness. Does anyone know the easiest way to get the ignition wires out so I would be able to easily connect the starter?
Old 12-18-2006, 05:50 PM
twistedtech twistedtech is offline
Re: I need help installing a remote starter
I have never heard if the EASY way. Nothing to do with a remote starter is easy. You have to split the harness at the bottom of the column, pull em ,out and your off to the races.You have a wiring diagram right?
If it ain't broke.......screw with it till it is.
Even at a Mensa convention,
Someone's the dumbest person in the room.
Old 12-24-2006, 03:17 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
twistedtech, there isn't any ignition wires at the column. They are off the right side of the dash. Take the knee knocker off and you'll see a thick, taped harness comming from the ignition switch. There is where you'll get your wires.
Be carefull on how you bypass the passloc system. It can be tricky for the first timer and it won't start if you have the key in the ignition. Just having the key in there won't make it send out the proper code. The code is sent when you turn the key.
Be extremely carefull on the parking lights!!!! Doing those incorrectly spells an expensive repair bill.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
