Go Back   Automotive Forums Car Chat > Cadillac > Catera
Old 12-18-2006, 03:55 PM
SteVB SteVB is offline
Question NOT charging, new alt & batt.
I have a 97 Catera V6, the battery was running dead, so we changed the alternator & battery & it still doesn`t charge. i looked at the big fuses under the hood & they didn`t look burned.
maybe fuse links??
HAS ANYONE HAD THIS PROBLEM????
Old 12-19-2006, 02:50 PM
yeyo yeyo is offline
Re: NOT charging, new alt & batt.
Hey man i too have a 97 catera, my prob thou was that the battery died al of a sudden, out of nowhere i go to crack it up n it doesnt work, i checked the fuses and everything checked out, i jump started it an it worked but after turning it of it wouldnt start again, i replaced the battery and it worked, it was all the battery itself ,maybe your prob lies with the battery, something might be draining it or ur belts arent working proply, hope this helps
Old 12-19-2006, 05:18 PM
DFBonnett DFBonnett is offline
maybe fuse links??
Have you checked the alternator output with a voltmeter? An alternator or battery DOA right out of the box is not unheard of.
Old 12-20-2006, 05:24 AM
i`ll check those, thanks, just seeing if there are any other experiences first.
Old 12-25-2006, 03:20 AM
PROBLEM SOLVED!! it was a defective battery,just goes to show, you never know.
Old 01-06-2007, 06:02 PM
halofive halofive is offline
steVB watch it for a minute. i have one as well with the same exact problem. i have been through 2 batteries and 3 alternators. mine is a open circuit for sure. thus y im on here to see if anyone has had this problem. so if it persist post back.
Old 01-30-2007, 04:45 AM
ATTN: HALOFIVE......UPDATE!!!!!!!!!!!!!!!!!!!!!!!!
The new batttery helped, but here a month later it died again, my brother who`s a mechanic looked at it & traced it back to a bad crimp from the factory on the pos batery cable where it goes into the batt. terminal., he cut that end off & put a new professionally crimped eyelug on the end & it charges beter than it ever has & CONSISTENTLY!! He said the cable end & terminal burned his fingers when he touched them it had so much rersistance & the connection was so bad. with the motor running, touch the battery terminals & wiggle the wire, i think that`ll be your problem. it`s FIXED!
