Old 12-18-2006, 12:38 PM
spackelman spackelman is offline
New Fuel Filter
FYI...
Replaced my fuel filter yesterday (guessing, I had about 40,000 mi) on it.
Did the "human blow" test - the filter was clogged to the point I could barely blow thru it.
I sliced it open just to see, would not believe the crap in the filter. I still can't believe the truck was actually running.
Seemed to notice a slight performance increase too.
I will start replacing at 15k to 20k from now on (or twice a year).
Merry Christmas!!
2002 Silverado 2500HD Crew Cab, Full Box
8.1
K & N Intake
Pioneer DEH960MP w/ Pheonix Gold Octane 5/4 Amp
Polk momo6500 Front Polk momo 650 Rear
Bulldog Auto Start
Old 12-18-2006, 03:33 PM
Sonny01's Avatar
Sonny01 Sonny01 is offline
Re: New Fuel Filter
I just replaced my fuel filter, cleaned the IAC and throttle body at 94k and it's like it's a new truck again.
Old 12-19-2006, 03:02 PM
silverado122775's Avatar
silverado122775 silverado122775 is offline
Re: New Fuel Filter
I think I will go get a fuel filter today
The filter has only been replaced once..bad bad me
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
Old 12-19-2006, 06:16 PM
wirles wirles is offline
Re: New Fuel Filter
I was told the 2004 models don't have a fuel filter. Anyone know if this is true?
Bill
Old 12-20-2006, 08:31 AM
Re: New Fuel Filter
I believe the 04 still has a fuel Filter.. it is located under the bed on the driver side along the frame.
Old 12-20-2006, 08:52 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: New Fuel Filter
Originally Posted by spackelman
FYI...
Merry Christmas!!
Your fuel pump will just love you for doing that.
Dirty fuel filters are the no. one killers of fuel pumps.
Depending on the gasoline you buy and where you buy it.
Some will make it a 100k and others only make it 1k or 10K.
Always buy gas at a high volume good grade of station.
Some good ones even have filters on there pumps.
Good luck and check or replace it ever so often and your fuel pump will have a long life.
MT
Old 12-20-2006, 10:59 AM
Re: New Fuel Filter
I forgot to mention, I put in 2 pints of seaform cleaner in my tank (34 gal, 1 pint treats 16 gal).
Don't know if it actually does anything but I figure it can' hurt.
8.1
K & N Intake
Bulldog Auto Start
Old 12-20-2006, 11:05 AM
Re: New Fuel Filter
How did or how do you clean the IAC (idle air control?), with simple spray cleaner?
8.1
K & N Intake
Bulldog Auto Start
Old 12-20-2006, 12:18 PM
MT-2500's Avatar
AF - Advisor
Re: New Fuel Filter
Seafaom is more for a winter storage gas conditioner.
But will not hurt it but may break lose some stuff so keep a eye on the filter.
Remember it catches it all.
Depending on what crap you have in the tank.
Was it rust or black stuff or moisture?
Heet or alcohol or ethanol will get the moisture out of it
You might want to run a little fuel injector cleaner threw it to.
Good luck
MT
MT
Old 12-20-2006, 12:26 PM
Sonny01's Avatar
Re: New Fuel Filter
spackelman
I just took it out and sprayed carb cleaner on it and wiped it off real good with a rag. I did that several times because it was really gunky.
