Old 12-18-2006, 11:06 AM
guitarfish's Avatar
guitarfish guitarfish is offline
Stripped wheel bearing bolt - do I have to drill now?
Hi guys,
Went to replace a front wheel bearing on a '98 GP this morning, and was stopped cold - one of the three bolts in the back that holds the wheel bearing in place went soft on me, the socket slipped off, and it's too rounded to get out. I even tried a 6 point socket, no good, it just strips off.
Is drilling the old bolt out the only way now? There doesn't seem to be enough clearance to chisel the bolt head off without damaging things. Assuming drilling is the only way, would you drill from behind where the bolt head is, or drill in from the outside, where the threaded end of the bolt sticks out?
Or any other suggestions?
Thanks,
-Dave
Old 12-18-2006, 02:50 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Stripped wheel bearing bolt - do I have to drill now?
They make a special socket for removing stripped bolt heads (craftsman and other companies make them) that has fluted points inside that grip the stripped head that may be a better alternative to drilling. Using a good penetrant like PB-Blaster or Break Away may help also.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 12-18-2006, 03:17 PM
guitarfish's Avatar
I wonder if something LIKE THIS would work.
Old 12-18-2006, 06:17 PM
redwheeler's Avatar
redwheeler redwheeler is offline
take a 12 point socket a size smaller than the one that rounded off the bolt and pound it on with a hammer give it a little heat and try that
and yes i am a ASE Master Auto Technician
1996 chevrolet silverado 5.7L 4x4
nothin but a k&n for now i just got it
Old 12-18-2006, 06:19 PM
guitarfish's Avatar
That's a good idea, I didn't think of that until I put the car back together
The bolt is 13mm, and 1/2" is slightly smaller. I'm gonna try some of this stuff and hopefully I get somewhere. Thanks for the tips guys.
Old 12-19-2006, 10:29 AM
richtazz's Avatar
That socket in the link you provided is useless Guitarfish. A friend of mine bought one, and it broke in to pieces the first time he tried to use it. He was using a short handled Craftsman 3/8" ratchet at the time, and I bet he was applying less than 60ft/lbs of torque on it.
Old 12-19-2006, 10:44 AM
guitarfish's Avatar
I figured it was too good to be true. I think I'm going to try the 12 point socket, slightly smaller. Stay tuned.
Old 12-19-2006, 12:10 PM
richtazz's Avatar
Here is a link to the Craftsman tool I was talking about.
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
Old 12-19-2006, 12:13 PM
guitarfish's Avatar
Excellent!!
Old 12-19-2006, 06:11 PM
guitarfish's Avatar
YOU GUYS ROCK !!
The bolt is out. The wheel bearing is out, new one in, case closed. I used a 1/2" 12-pt socket, smacked it on real good, and off she came. Whew, huge sigh of relief!! Thanks so much for all the help & suggestions. I was actually going to buy the Craftsman damaged bolt removers tonight, but got side tracked and couldn't stop - turns out I didn't need them after all. But it's good to know such a thing exists.
Thanks all. I'll be back in a week for the control arm bushing, LOL!
