Old 12-18-2006, 12:47 AM
chivid chivid is offline
My car idles at 2000 rpm when first started
ive been noticing that my car's idle goes to 2000 rpm every morning but then it goes down after like 2 minutes of leaving it running. i check all the vacuum hoses and they're all fine. it only really does it when its cold but it idles fine after its been warmed up. i think my temp sensor on the head might of gone bad. any ideas of what it might be?
Old 12-18-2006, 02:54 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: My car idles at 2000 rpm when first started
How cold does it get in your area. Depending on if you have a FITV and what temps you're experiencing, this may be normal.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 12-18-2006, 03:18 AM
maxassassin's Avatar
maxassassin maxassassin is offline
Send a message via AIM to maxassassin Send a message via MSN to maxassassin
i live in idaho and it gets below freezing. it does this with my vehicle all the time. i figured its sjut normal to build heat i suppose.
06 cbr 600 f4i
91 civic hatchback.
96 nissan pathfinder
Old 12-18-2006, 01:08 PM
thedeadcivic's Avatar
thedeadcivic thedeadcivic is offline
this is normal in cold weather. once your car warms up, the idle should drop to about 1000 rpm. i dont usually drive it when its this cold because my car tends to bog out when i make corners if my rpms get lower than 1500.
anyways... this is completly normal in the cold weather. the car will rev higher to get hotter faster. you shouldnt worry about it. it wont do this in warm weather.
90' Honda Civic Si
2001 Volkswagen Golf 1.8T
Old 12-18-2006, 02:24 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Mine does the same thing.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 12-18-2006, 03:48 PM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
normal here this time of the yr..dunno about Cali tho
