Old 12-17-2006, 07:57 PM
RalliArt3kGT's Avatar
RalliArt3kGT RalliArt3kGT is offline
Send a message via AIM to RalliArt3kGT
Question USB Help
I've got a Compaq Presario 2100 Laptop and I managed to mess up both USB ports in the back, so they no longer work. So my sister came home from college for winter break and I had her bring her PCMCIA USB card home with her and I put it in and plugged in my iPod cable into it, and it freezes up my computer and then gives me a USB port power overload message. So, is it just the cheapo eBay PCM card, or will no PCM USB cards work with my iPod. I don't really want to have to replace the USB ports in the computer, but if I have to I guess I'll just have to. Would that be something I could do on my own or would I have to bring it somewhere and get it done? Thanks for the help.
-Russ
Old 12-17-2006, 09:20 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: USB Help
How exactly did you screw up the original USB ports?
Did you install the PCMCIA card properly? Usually those things require certain drivers to work if your not running Windows XP. What OS are you running? Did you try plugging something else into the port besides your Ipod?
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 12-17-2006, 10:02 PM
Re: USB Help
Well, I'm not entirely sure when/how I messed it up, but since I've had the computer the prongs on one port folded in half and the other one just kind of got fubar'edand quit working on me...basically I'm a retard.
As for the PCM card, I've unistalled and reinstalled it a few times, so I would hope that at least one of those times I would have gotten it right. I haven't tried plugging anything else into it, I don't really have anything else that uses a USB, I guess you could say I'm pretty low-tech like that. Oh yeah, I'm running XP for my OS.
-Russ
Old 12-18-2006, 12:41 PM
bjboertje's Avatar
bjboertje bjboertje is offline
Re: USB Help
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Rainbow CMX 265 front stage
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 12-20-2006, 10:09 PM
Re: USB Help
anyone else got any ideas?
-Russ
Old 12-20-2006, 11:02 PM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Send a message via AIM to Oz
Re: USB Help
Try deleting all the USB root hub drivers in Device Manager and rebooting.
Originally Posted by RaeRae1
Blessed are the cracked ones for they are the ones that let in the light.
Old 12-21-2006, 09:38 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
Re: USB Help
Sounds like you shorted out the USB ports when the one folded over. I've seen it happen on the Sony's. If that's the case no USB devices will work until you get that fixed. It's a part of the mainboard so you might be able to solder a new one in or disable it by scratching out the lands going to it.
You might also disable the onboard USB in CMOS which would allow you to use the PCMCIA card. Maybe. Good luck.
Old 12-21-2006, 11:23 PM
Re: USB Help
Did this, the one USB in the back that is less broke than the other one recognized a USB device was attached, but then froze up and wouldn't do anything until I unplugged my iPod. So it sounds to me like this is what happened
Only problem is most of that is over my head, soldering and scratching stuff out on the mainboard...I'll pass. Looks like my computer's goin in for a repair job after the holidays.
-Russ
Old 12-23-2006, 01:04 AM
Re: USB Help
From the sounds of it, you might just as well buy a new, cheap computer. It's not gonna be worth it after some shop charges you $75/hour plus parts.
'92 3000gt SL
Zoom Stage 1 Clutch
