Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 12-17-2006, 06:40 PM
cbnight cbnight is offline
Smile Cant Drive At Night....HELP!!
hey everyone i need some help, i have a 98 s10 v6 and the day time running lights dont work as well as the low beams and half my dash lights, they only thing that works perfect is my high beams, if anyone knows what to look for please let me know i would appreciate it, thanks!
Old 12-17-2006, 09:38 PM
berniescout berniescout is offline
Re: Cant Drive At Night....HELP!!
have you tried new low beam bulbs? change out 1 and see if it works before doing the other. low beams burn out more often. my 97 uses the high beams for daytime running lights. check out the light switch on the steering column. the is a post about it on this site.
Old 12-18-2006, 02:29 AM
riptide44 riptide44 is offline
by chance do you tow a trailer ? i recall replacing a buddies light switch that had melted - it was cuased by a frayed power wire that was touching the metal frame of the tailer .. at any rate it sounds like the light switch itself is the problem .
Old 12-18-2006, 07:13 AM
Scrapper Scrapper is offline
AF Premium User
check the ground wire to the body to and to the motor.....
Old 12-18-2006, 07:14 AM
AF Premium User
check the ground wire to the body. and to the motor.....
Old 12-18-2006, 09:21 PM
DelCoch's Avatar
DelCoch DelCoch is offline
Originally Posted by cbnight
. . . only thing that works perfect is my high beams, if anyone knows what to look for please let me know i would appreciate it, thanks!
Do you have any kind of auxiliary lights, fog lights, etc, especially after market stuff?
Old 01-04-2007, 09:09 PM
reubenator reubenator is offline
Sounds like the low/high beam switch. I had a similar problem afew weeks ago where I didn't have any low beams except daytime until I tried the low/high switch a few times. Problem has not returned but it was linked to that switch.
Old 12-24-2008, 07:24 PM
s10drivemecrazy s10drivemecrazy is offline
i suggest put a light rack on the back and mount some heavy duty off road lights up top, plenty of light
Old 12-24-2008, 08:14 PM
old_master's Avatar
Advisor/Moderator
Please check the date before you post in old threads, this one has been dead for almost 2 years. Thanks.
Closed Thread
