Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 12-17-2006, 05:40 PM
dxegrl77's Avatar
dxegrl77 dxegrl77 is offline
Send a message via AIM to dxegrl77 Send a message via Yahoo to dxegrl77
Smile 91 Ford Explorer help
I have a 91 Ford Explorer that is making noises. it is this clicking noise, looked under the hood and realized the AC Compressor was making the noise by stopping and starting. I did not have the ac or heat on and it still did it. is there something i can do to avoid taking it to a mechanic for now. weather here mild enough not to need ac or heat except for defrosting. can anyone help?
Old 12-17-2006, 08:16 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 91 Ford Explorer help
Did you have the defroster on when you noticed the compressor was making the noise? If the ambient temperature is above freezing, the compressor will turn on with defrost to remove the humidity from the air.
If you did have the defrost on, it sounds like the A/C system is low on refridgerant. If you want to disable the A/C compressor clutch for the time being to avoid wear and tear on the system, you can unplug the compressor clutch or the pressure switch. Just be sure to tie the unplugged connector up and out of the way of moving or hot parts.
If the compressor is kicking in with the HVAC system turned off, then there is some other issue that will need more investigation. Unplugging either of the connectors mentioned above though SHOULD still disable the compressor clutch.
-Rod
