Old 12-17-2006, 05:00 PM
mitchdakid mitchdakid is offline
AOD wiring
Just came acrossed a AOD trani and want to throw it in my 67 mustang, have a few questions have everything figured out on how to make it fit, and flywheel changes and all that, but my one problem is how do I wire it up, I have the wiring harness and everything just not sure where the wires get connected to or if I have to terminate them somehow seeing there is no computer module. Any help would be gratefull thanks.
1967 mustang coupe
new candy apple red paint with charcle striping, 351 windsor rebuilt 100 miles ago, 463 butt gears, B&M QUICK SHIFT, c-4 Transmission, shaved door handles, custom interior - not finished yet, 68 gt wheels-powder coated, slicks for the track, mustang 2 suspension.
1996 Blazer LS 2 door 4wd
aftermarket muffler-Flowmaster 40, cold air intake coming, blazer extreme body kit on it's way also, front has been lowered with tensioners, and rear with a block.
Old 12-17-2006, 05:21 PM
restomod's Avatar
restomod restomod is offline
Re: AOD wiring
Is it a AODE or an AOD? AODE is a fully electronic trans.
An AOD wiring is composed of the back up light and saftey switch, but you can bypass them and everything will work. I can't remember how many wires were involved, but I believe 2 were for the saftey switch and 1 for the back up light.
Restomod
www.yamaberacing.com
65 Mustang 2+2
351W- Lentech AOD
Novi 2000 supercharged
Old 12-17-2006, 07:54 PM
Re: AOD wiring
Hmm not quite sure how do I tell, if it is not an AODE then do you know how I can bypass the whole thing. It has a small wiring harness coming off the trani consisting of 4 wires, if that helps at all. Thanks
1967 mustang coupe
Old 04-26-2007, 03:45 PM
Msvic Msvic is offline
Re: AOD wiring
Sounds like you have a non computer AOD.
Simply plutg in that 4 prong switch into the trans, hook up 2 to your neutral safety switch & turn the key until it won;t turn over & you;ve found the 2 wires you need, just tape the other 2 together.
I think its the brown/black ones.
The critical part of running an AOD is the TV cable
Unlike a C-4 trans the AOD works on pressure & throttle position to shift.
Run it without your TV cable hooked up & you WILL burn it out in under 100 miles
The TV cable runs from the trans to you carb or EFI whatever your running, adjustment is critical.
go to windsorfox website ot lentechautomatics to see how to hook it up.
If you don;t have this TV cable they can get you one or visit your local wrecker
Good luck
