Old 12-16-2006, 10:21 PM
tigeraid's Avatar
tigeraid tigeraid is offline
Authorized Vendor
Why does Tamiya hate me?
For the longest time I lived up north and had no LHS, so I had to go with what Wal-Mart carried, in this case Testors spraypaint.
Moved here and finally had an LHS, and everyone raved about Tamiya paints in terms of quality. Well I gotta tell ya, it's been 50/50 for me and Tamiya paints. Why is it so damn hard for me to lay a consistent paintjob with TS sprays?
The Camaro SS project (see WIP) has been about 80% done for the last week, because I had to paint it, and then strip the paint twice. Both times I got severe, SEVERE bubbling fisheyes along every panel line. It was almost as if the panel lines WERE fisheyes, that's how bad it was.
I went through all the typical reasons for fisheyes--humidity, particulates on the body, moisture on the body... prepped it perfectly, washed it with soapy water, gave ample drying time.... laid 2-3 very thin mist coats... didn't matter, they just came back.
So this situation again brought back my love for Dupli-color's simple automotive paints. They work so flawlessly it's scary--and they're half the cost of Tamiya paints! Stripped the car a third time, did no additional prep work, no change to the environment, and laid down a perfectly smooth paint job. This just reinforces my belief that I need to stick with Dupli-color unless absolutely necessary.
Anyway... feel free to offer suggestions of what went wrong, but mostly this was just a rant I had to get off my chest opcorn:
Old 12-17-2006, 01:37 AM
klutz_100's Avatar
Re: Why does Tamiya hate me?
It's because they have noticed that you are in a conspiracy with Aoshima and thay want revenge!!
Seriously though, it is not unknown for a bad can of Tamiya TS to turn up once in a while - particularly in some colors. They are great paints IMO but not perfect.
What color were you using?
Sometimes I guess it's good to just stick with what works for you already...
Old 12-17-2006, 02:21 AM
tigeraid's Avatar
Authorized Vendor
It was black... and honestly like I said, it was always a 50/50 shot for me... and it always seemed to be that SAME problem too, with severe fisheyes... I've never had any other kind of problem with TS paints.
Old 12-17-2006, 04:19 AM
DVST8R DVST8R is offline
I've never had a problem with black, I usually have problems with tamiya's yellows and silvers. Though today i had bubbling problems with blue, but it is a 3 year old can.
Old 12-17-2006, 04:32 AM
Hiroboy's Avatar
Hiroboy Hiroboy is offline
www.hiroboy.com vendor
I gave up with Tamiya Black last year, it was getting rubbish and I could never get it down nice either. I think they changed the fomula .
Steve a.k.a. Hiroboy
Old 12-17-2006, 04:44 AM
rod_k2's Avatar
rod_k2 rod_k2 is offline
Send a message via MSN to rod_k2
Uhhh.. I've painted mine with tamiya black! But white primer as a base. Went out not bad! Only problem is that the paint ended...But,yours is a TS color,mine was airbrushed...But,was black...
"Oh noez,it has more stickers than me! And a wing too!
Old 12-17-2006, 08:47 AM
freakray freakray is offline
AF Modelrater
Along panel lines sounds like you're laying the paint down too heavily and trapping propellant in the paint which can result in bubbles as the gas tries to escape.
AF User Guidelines
Old 12-17-2006, 09:19 AM
Gamerxz's Avatar
Gamerxz Gamerxz is offline
Everyone has their own way of laying paint down i guess... tamiya seems to be my best colour... i always get a super shiny finish even even without sanding the last wet coat... oh well
Old 12-17-2006, 09:52 AM
scaleracecars scaleracecars is offline
I think Ray has it right. It is most likely for you to have more paint in the panel lines and more likely to have gas trapped. You might want to try spraying from father away to solve the problem and laying less paint on per coat. I suggest spraying the panel lines first and laying down at least two coats on them before painting the large areas of the body. I like to spray the holes, panel lines around windows etc.. until I am happy with them then I worry about the large areas of the body.
David
Old 12-17-2006, 10:44 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
I'm with Klutz, I think it is your recent alliance with Aosima.
But I'm also with Ray. It sounds like laying down thinner coats and leaving more time in between them may make all the difference in the world for you. TS is easy to get good results from, but often it requires considerable patience in applying it.
PHOTOBUCKET SUCKS
Old 12-17-2006, 11:16 AM
tigeraid's Avatar
Authorized Vendor
Good call, that may very well be the case... But I mean, it's not as if I changed my method and, like I said, the exact same method worked great with dupli-color... I did try several fairly fine mist coats first though...
Old 12-17-2006, 11:20 AM
Dean23's Avatar
Dean23 Dean23 is offline
I used tamiya ts 14 black for my 67 chevelle( see tamiya gallery for pics). It was my first black model and my only time using tamiya. Iused to use testors, but that up and down love affair is over. Could testors make a can that can spray a mist not shoot out globs of paint. Maybe you have just gotten unlucky with a bad can of paint, or maybe it doesnt like your primer. Not really sure though. Keep on trying though and dont be to disgruntled!
get me a hardtop with a decent engine and make sure it's got a big trunk
Dwight from Sin City
Modern cars - they all look like electric shavers
Marv from Sin City
Old 12-17-2006, 11:35 AM
tigeraid's Avatar
Authorized Vendor
You know that's a good point, I am using Dupli-color primer... but they're both acrylics and worked together in the past... maybe I'll give it one more try on my next model with Tamiya primer...
But I think the price issue is the real deal breaker for me. I can buy huge cans of dupli-color for $9 cdn and get 7-8 cars out of them, vs 2 for a small Tamiya can that costs $9.99.
Old 12-17-2006, 12:12 PM
hirofkd's Avatar
hirofkd hirofkd is offline
I think that's the exact problem. Tamiya and Dupli-color are different type of paints, so you must not spray the same way.
Dupli-color dries much faster than Tamiya's, so Dupli-Color's gas is less likely be trapped even if you apply a relatively thick coat of paint. But if you do that with Tamiya (or any other hobby paints for that matter), you're taking a great risk of trapping gas, which causes fisheye.
Next time, make sure you keek a certain distance for the gas to evapolat, and also avoid wet coating.
Hiroaki Fukuda
Old 12-17-2006, 01:44 PM
bhop73's Avatar
bhop73 bhop73 is offline
Me too.. i've never had one single little itty bitty problem with Tamiya TS
http://www.bhop73.com/
