Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 12-16-2006, 09:29 PM
only 205 hp only 205 hp is offline
Question High Stall Torque Converter?
Someone gave me advice to install a high stall torque converter if I plan to do performance installs to my car. I would like if someone would explain to me in the most detailed way what exactly it does, and how I would utilize it.
Old 12-16-2006, 11:09 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
Re: High Stall Torque Converter?
http://auto.howstuffworks.com/torque-converter.htm
basically it is just a performance version, or a more effective version of what you already have.
Don't act like you don't love it.
503/2000
Old 12-17-2006, 02:48 AM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
can installing too high an rpm converter affect drivability? Is it harder on your trans? I understand that dropping an auto trans from N to D is very bad, but does it basically do the same thing as a high stall converter? I have a manual, but am a little curious if the only thing a high stall does is allow you to launch ata higher RPM when you are in drive. For the benefit of this post, please put some notes as to how high an rpm converter to get (if there are choices).
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 12-18-2006, 01:08 AM
Sleepr awd's Avatar
i guess you all are going to make me work for this one right?
HSTC's available
http://club3g.com/forum/showthread.p...rque+converter
how to make your trans shift faster:
and a more absolute answer on making an auto trans faster:
but i'm not finding much on which one to use, because probably, that most people dont' break 400whp on the 3g eclipse, so there is really only stage 1 and 2 setups.
503/2000
