Go Back   Automotive Forums Car Chat > Buick > Regal
Old 12-16-2006, 07:55 PM
derrik38 derrik38 is offline
Question drive are overdrive?
i have a 92 buick regal.i know on the highway its better on gas mileage in overdrive.what about just in town.slow speeds? also can i whicth from overdrive to drive while cars moving are should i wait tell i come to a stop?
Old 12-16-2006, 09:17 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Wink Re: drive are overdrive?
The auto overdrive engage function, is controlled by the speed of the car and overdrive (4th gear) will usually not engage under 45 mph. It would not be wise to drive the car in “drive” at speeds in excess of 45 mph, due to the higher rpm requiring more fuel and generating excessive engine temperatures. It is ok to shift from OD to drive, while driving at lower speeds. If you are driving @ 80 mph, it might not be a good idea!
Old 12-16-2006, 11:19 PM
Thumbs up Re: drive are overdrive?
thank you.my car has a gear shift for drive and overdrive.so a low speeds should i leave it in overdrive?
Old 12-17-2006, 07:38 AM
HotZ28's Avatar
AF Moderator Elite
Yes, OD is fine. The transmission will select the best gear for your driving style & conditions.
