Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 09-20-2002, 12:44 AM
teck teck is offline
Send a message via AIM to teck
suspension problem
my rear passenger side makes some kind of a noise like metal with metal grinding every time i hit a bump. when i do hit a bump it sounds like if it slams as hard as it can does any one know what the problem maybe
check out my ride at:
http://www.cardomain.com/id/civs2000
Axis MOD 7's 18" - S2000 tailight conversion - Antenna, trunk & moldings shaved - APR mirriors - molded black widow 2 rear - Tokico Gas Shocks - Skunk 2 Coilovers - ALPINE CDA-9855 - iPod Adapter - Deck - Pioneer Digital EQ Hifonics - 1000w Alpine-600W Subs-12" Kicker Comp VR - 2 7in. visor t.v's - 2 12 in. t.v. on my roof heh
Old 09-20-2002, 06:39 PM
Duatone Duatone is offline
do you have those rubber spring caps on? the ones that center your spring at all times, I forget what they're called, if not check to see if your spring is seated evenly in the upper spring cup, or do you even have your upper rubber sping cup in? sorry, these sound like stupid questions, but trust me, ive seen it done, then the spring will sit in the cup cock-eyed and rub on the inside of the cup whenever you hit a bump or such, like an irritating metal on metal sound.
so far:
1990 accord ex
JDM F22B DOHC/Nakayama cold air intake/Nakayama exhaust/18" Enkei Zoku painted black/Yokohama Parada Spec II/Full air ride/shaved doors & mouldings/VIS R34 front bumper blah blah blah...
Old 09-21-2002, 12:14 PM
thanxs for your help. i fixed it already
2001 Interceptor version, suspension problems... ratherbestrummin Crown Victoria 0 07-22-2009 07:20 PM
putting on the suspension..PROBLEMS!!! jkicv Integra 3 04-07-2003 03:52 PM
help suspension problem michaeldick '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 12-16-2002 11:02 PM
Desperately need professional opinion for my suspension problem xlosinghopex Tires and Wheels 6 11-18-2002 08:56 PM
Suspension problems... body rot? & air bag suspension... PLEASE ASAP! sparq Engineering/ Technical 4 12-06-2001 02:20 PM
