Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 12-16-2006, 06:43 PM
zeek1403 zeek1403 is offline
Angry losing oil
My 99 Ranger with a 4.0 seems to be losing oil. I started out with 5W-30 when I bought it a few months ago and it seemed to run through it. Switched to 10W-40. Same thing. Should I switch back to 5W-30 and use Lucas oil with it? I know Lucas is a great product so I'm just wondering if that might fix the problem. The average loss is about 1/2 quart every 200-300 miles. New valve cover gasket. I don't see any visual smoke any time. Any help is greatly appreciated!
Old 01-05-2007, 07:43 PM
rhandwor rhandwor is offline
Re: losing oil
Some more information would be helpful. Is smoke coming out of the exhaust?
Is oil dripping on the garage floor. If so front or back of engine. Is it dripping around the oil filter?
Check for a plugged pcv system
Old 01-05-2007, 10:39 PM
Re: losing oil
As I said, no smoke. There are no leaks anywhere. I just replaced the PCV valve.
Old 01-06-2007, 12:03 AM
DonSor DonSor is offline
Re: losing oil
It's either you are burning it or leaking it. If its leaking, it's either leaking out of the engine or, could be leaking into the cooling system. Check your coolant for any signs of emulsification.
Old 01-06-2007, 05:54 AM
e_powers e_powers is offline
Re: losing oil
if you are burning, check your compression. if the plugs are good, and your compression checks out, then you have bad valve guide seals/seats.
if your plugs are fouled or messy then that would cause missing oil
if your compression dont check out then rebuild time.
if i had to choose i would choose bad valve seals.
starting to love my 93 ranger w/3.0 5 speed.
Old 01-06-2007, 06:36 AM
Scrapper Scrapper is offline
AF Premium User
Question Re: losing oil
i agree valve stim seals if all other's posting's checks out...good luck...
Old 01-06-2007, 08:04 AM
Re: losing oil
If your valve stem seals are leaking you should get smoke on start up which clears up.
You can change them by either putting air in the cylinder or some people slide some rope into the spark plug hole and turn by hand until the valves are against the rope. This way you don't have to pull the head. Go to a machine shop and buy umbrella seals.
Old 01-06-2007, 02:07 PM
Re: losing oil
Sounds like arthroscopic repair. I also have a '99 Ranger 4.0L. If your problem is internal, you are surely going to have some visual indication (smoke, fouled plugs, etc.) and for sure you will feel it in your truck's performance. Hate to say this but it looks like you may have to tear the engine apart to fix the problem.
Old 01-07-2007, 08:51 AM
Re: losing oil
I recently changed the spark plugs and there is no fouling going on. Also, no visual smoke at startup. When I change the oil in about 1000, I'm going to try about a quart and a half of Lucas with 5-30. It seems to be worse off with 10-40 for some reason.
Old 01-07-2007, 09:05 AM
AF Premium User
or try using rotella made buy shell....good luck..
SCRAPPER.......
Old 01-07-2007, 11:39 AM
Re: losing oil
This might give some leads on the case: I just put in a new PCV 2 weeks ago and the new one already has oil on it. I'm thinking that it might not be a good thing. What could be the problem and how easy is it to fix?
Thanks in advance!
Old 01-07-2007, 07:19 PM
Re: losing oil
Its an indication of a blow-by. But using oil that much surely should have some other indication. No emulsified coolant, right. I'm skeptical about using "miracle" additives. It may hide the symptiom but don't take care of the problem. I use 5-30W in my '99 Ranger 4.0 and at 82K miles, I'm hardly low half-a quart by the time change oil (5K miles) is due. Frankly, from what you've been saying, I'm somewhat stumped for answers.
Old 01-07-2007, 08:39 PM
Re: losing oil
What is a blowby and how can I fix it?
Old 01-08-2007, 07:26 AM
AF Premium User
Exclamation Re: losing oil
blowby is a indacationg of bad rings if ou tak your oil cap off and have it running if smokes coming out indacates bad or worn rings...good luck..
scrapper.....
Old 01-08-2007, 07:34 AM
AF Premium User
[quote=Scrapper]blowby is a indacationg of bad rings if out take your oil cap off and have it running if smokes coming out of the oil hole indacates bad or worn rings...good luck...
