Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 12-16-2006, 06:43 PM
zeek1403 zeek1403 is offline
Angry losing oil
My 99 Ranger with a 4.0 seems to be losing oil. I started out with 5W-30 when I bought it a few months ago and it seemed to run through it. Switched to 10W-40. Same thing. Should I switch back to 5W-30 and use Lucas oil with it? I know Lucas is a great product so I'm just wondering if that might fix the problem. The average loss is about 1/2 quart every 200-300 miles. New valve cover gasket. I don't see any visual smoke any time. Any help is greatly appreciated!
Old 12-17-2006, 06:40 AM
e_powers e_powers is offline
Re: losing oil
nope, it will help for a little bit, but then after the stuff is gone or wears off the leak will be worse.because that kinda of stuff causes gaskets to swell and that causes leak to subside after a bit they shrink, and most times making the leak bigger. it is best to clean the engine of all oil on the outside and check to see if there are any visible leaks
starting to love my 93 ranger w/3.0 5 speed.
Old 12-17-2006, 08:15 PM
DonSor DonSor is offline
Re: losing oil
e powers suggestion make sense. It's either leaking or burning oil. Half a quart every 2-300 miles you will surely notice oil spots in your driveway. How is the truck running otherwise? re: performance. Check a couple of your plugs for oil fouling, also your PCV. I also have a '99 Ranger 4.0 and I use the recommended viscosity oil. I'm hardly half a quart low when I'm due for oil change 3-4K miles. Recently
Old 12-29-2006, 08:48 PM
4x4grey88's Avatar
4x4grey88 4x4grey88 is offline
Re: losing oil
If there is no oil 'slick' on your driveway (that would indicate a leak), you can pull your spark plug to see if there is any oil residue.
If there is you have bad rings on the cylinder or valve seals. If you have blueish smoke from the exhaust that would also indicate oil burning.
The weight of oil only makes a difference with engine and ambient temperatures.
www.jeepforum.com; www.socalultimate4x4.com
1998 Wrangler (replaced my 88 XJ)
21' Mini Winnie (replaced my Pace Arrow)
