Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 12-16-2006, 01:30 PM
GMCjet52 GMCjet52 is offline
Question Passenger side seat heat not working.
For some reason my wife needs her seat heater to work. What usually goes bad on these things? The heat doesn't work at all, but everthing else on the seat works fine.
Thanks in advance, Gary.
1999 GMC Suburban SLT
Old 12-16-2006, 02:16 PM
taxidermist taxidermist is offline
Re: Passenger side seat heat not working.
Was her seatbelt on? My 99 will not work on the pass side unless they are wearing the seatbelt. I took it to dealer because my buddy rode home from up north with me and said the seat heat dont work(he dosent wear a seatbelt) and the service guy sat down in it plugged in the seat belt and I went DUH!!!!!!!!!!!!! and felt dumb.
Rob
Old 12-16-2006, 06:29 PM
Rob
She normally wears her seat belt, but i'll give it a try. The problem might be with the seat belt. Thanks for bringing this to my attention. I'll keep you posted on the outcome.
1999 GMC Suburban SLT 1500 4x4 bone stock
Old 12-17-2006, 03:03 PM
777stickman 777stickman is offline
Other things. Heated seat module, switch, seatbelt switch (pass only), heating elements (seat cushion and seat back), power feeds (one for the module and another for the switch) and grounds.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 12-17-2006, 03:11 PM
-The heat switch works, I swapped it with the drivers side.
-I'm getting 12 volts at the switch
-Will both Heat elements go bad at the same time?
-Does the seat need weight on it before the heat works?
-I checked the seat belt switch with an Ohm meter, its checks good.
-I also swapped a relay (located under the pass seat) with the drivers side with no changes.
Old 12-17-2006, 06:34 PM
Gary: Keep in mind that I'm looking at a '98 service manual. I'm assuming the relay you swapped was in fact the module (6 wires going to it). My diagram shows no switch for seat weight. The only other thing I see is in the seat cushion element. There is a temp sensor that shuts off both elements when it reaches a predetermined (?) temp.......Steve
PS: Check your private messages
57 Chevy 210
