Old 12-16-2006, 10:06 AM
comet240 comet240 is offline
dexcool and electricty
hi i lost the card that came with my heater core telling me what the electricty value should be in the radiatiator i getting 1.50 volts but cant remember if thats too high or not to cause pin holes in the heater core
right now i have a mix of dex cool and dex cool compatible for the lose of rad coolant
anyone know the electricty value i dont wanna replace it again in 3 months
Old 12-16-2006, 10:22 AM
maxwedge maxwedge is offline
A990 racer
Re: dexcool and electricty
.2 or over stray volts in the radiator is a problelm.
Old 12-16-2006, 10:25 AM
oh so then the 1.5 i getting is bad what can i do to fix it? and did i do it right i put ground in the coolant and the positive of the meter to the positive of battery
Old 12-16-2006, 10:32 AM
A990 racer
Wrong, positive in the coolant gd to the battery gd. Check it, then turn all the lites and accessories on and see what the vom says, post back, rmember you may the millivolt scale on the vom.
Old 12-16-2006, 10:35 AM
oh ok ya my volt meter i have to get my other one but it ony does 0.00 as a reading but ill go test that now with everything on
Old 12-16-2006, 10:44 AM
ok still 0.00 on my meter so i guessing that is good why when u reverse it u get voltage? i made a switch so u can turn on and off the day time runnign lights so save battery and i noticed when heads on it jumps to 2 volts if i did it the opposite way u said
Old 12-16-2006, 01:38 PM
A990 racer
Thats because you are getting some current flow from the battery through the coolant, not to worry the condition will not happen that way.
Old 12-18-2006, 02:40 PM
ah ok thanks very much
