Old 12-16-2006, 05:14 AM
Billy Rubin Billy Rubin is offline
White wall Tires.
I am currently planning my AMT/ERTL 36' Ford coupe and am wondering how to convert the tires into whitewalls?
Is there any paint that can be used or are decals the best way to go? IF so where would i get decals? I am quite new to modelling and want to do things right for the best outcome.
Old 12-18-2006, 02:47 AM
klutz_100's Avatar
Re: White wall Tires.
I haven't got a clue but since noone elase seesm to have any ideas let's give it a go
  • I made a Revell cord in 1/25 which had whitewalls you might try to find that kit. Actually the white walls were plastic inserts into the tires.
  • You might try making and painting? I don;t know how the oaint would stick though. Maybe r/c paints which I think are supposed to be more flexible?
  • Several coats of thinned out correction fluid?
  • Actually I wouldn't be very optimistic about white decal paper, but who knows...?
Good luck though and if you find a good method, remember to share it with us all!!
Old 12-18-2006, 04:08 AM
MILLER_MP6's Avatar
MILLER_MP6 MILLER_MP6 is offline
hey billy.. i havnt had much luck with decals. i paint them. I just use several coats of matt white paint. Its time consuming as it is important to wait til each layer is total dry before applying the next otherwise it tends to just spread around and not cover the section you are painting.. this works for me and im doing it on my '49 merc as seen in the Hot Rod section..
good luck mate
miller
Old 12-18-2006, 06:59 AM
accord2k2 accord2k2 is offline
billy just use arcrylic paint but be careful they tend to rub of if you play with them too much. but other than that a couple good coats and youll have them.
Old 12-19-2006, 01:17 AM
chato de shamrock chato de shamrock is offline
pegasus hobbies sell white wall tires; however, im not sure if they'd be the right size tires for your model. I also bought some white wall plastic decals off of them about 9 years ago. Who knows? Maybe they still sell them. You peeled off the paper on one end and stick the white wall to the tire. You then rub it into the tire really good and finally slowly peel off the other paper. The white wall should stay nice and tight on the tire. Thats how i made my first white walls.
HEY!!! HEY!!!
