Old 12-15-2006, 10:57 PM
pbrizzle86 pbrizzle86 is offline
Send a message via AIM to pbrizzle86
question of the wiring sorts again
ok i been having a lot of problems with my wiring in my honda. thought it was the ecu, and it did take care of a few things when i got a new one, but it also gave me a few more. well for starters when i press the brake pedal and the rear lights dont come on but the door ajar light comes on when i press the pedal. the new ecu took care of the map sensor issue i was having but now im throwing a code 4 for crank position sensor but i dont think i touched the wiring for that. only the shit on the C clip was messed with at the ecu. any ideas getting ready to just put the thing in storage untill the spring and forget about the honda for a bit, but i would really like to drive her a bit more this year. probly getting sick of me asking but i just dont know anymore. also is the wiring for the 89 civc the same coming off the ecu as the 90 dx of course. i been using the wire chart off of http://www.50mod.com/fourthgenhatch/mpfi.html and was wondering if it was the same between the years. thanks
Old 12-16-2006, 07:14 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: question of the wiring sorts again
Yes, it's the same.
As for the wiring issue your having, it's apparent that you have a short somewhere. Do this: remove all of your fuses under the dash. Put one fuse in at a time, then hit the breaks to see if the door ajar light comes on. If, when you insert a fuse and press the brakes the door ajar light comes on, you've now found what circuit in the car is shorted out. Then, you can troubleshoot that particular circuit.
As for the code 4...does your car still run ok though? If you are really experiencing a code 4, the car will run like poop. If it's running fine, then don't worry about the code. Try resetting the ecu first. If you still have the code, use a multimeter and test the applicable wires for continuity.
If you need anymore help, let me know.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 12-16-2006, 11:28 PM
no the car is not running ok it will idle ok but when you give it gas it dosent know what to do for a bit then backfires. i will check the wiring and get back to ya . also this code 4 thing is strange because when i plug in my ecu that has the bent pin on it the car dosent trow a code 4 only a 3 for the map sensor. i would like to test this ecu in another car but i dont know anybody who has the same car or an si.
Old 12-17-2006, 01:47 AM
bambam89lx's Avatar
AF - Advisor
do me a favor and tell me the ecu code on the ecu you are running now...
Old 12-17-2006, 02:24 PM
do you want the full code casue i dont have the car here it at the parents house. but it was just a stock pm6 i just bought and before that it was a chipped pm6 thats the one with the bent pin. i also have a pg7 laying around too. but iff you want the whole code i can probley grab it in a bit here
Old 12-17-2006, 07:37 PM
bambam89lx's Avatar
AF - Advisor
No, I just wanted to make sure you were using a PM6. Give the PG7 a try.
