Old 12-15-2006, 06:03 PM
G-man422's Avatar
G-man422 G-man422 is offline
New to car audio.
Im curiouse what it would take (money, tools, equiptment, etc...) to hook up my own audio system (amp, speekers). I need some good sites, and good info on ALL the stuff involved, but in simple terms.
Thanks: G-man422
Old 12-15-2006, 08:14 PM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Re: New to car audio.
Welcome to one of the worlds most expensive and addictive hobbies.
this should get you a basic idea of whats needed to get a complete front/rear and sub stage
http://www.automotiveforums.com/vbul...d.php?t=382679
this will teach you all the basics of the electrical terms and how some things work and such
http://www.bcae1.com/
this should help some
http://www.the12volt.com/caraudio/caraudio.asp
this should help some also
http://www.carstereo.com/help/Articles.cfm
Like everything else in this world you get what you pay for in most instances you can notice a severe difference between a subs that cost $50 and one that cost 3-4 times that much, look at the brand rating list it helps give an idea of what to look for.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 12-16-2006, 07:55 AM
G-man422's Avatar
Wow, thanks man. Thats some great info. I'll let you guys know if i have any more questions.
G-man422
Old 12-19-2006, 04:43 PM
Laoboiracer14 Laoboiracer14 is offline
I need help...i tried to fix my stereo..so far i hooked up everything..the power cable to the amp...speaker wires to the sub..i bridge it also..im running a 600 watt kenwood amp and 2 MTX subs. theres a fuse on the power cable and i changed it and when i turn on my car the fuse blows and the amp and subs dont work...i need help on what to do...should i buy a new power cable?
Old 12-19-2006, 08:44 PM
Wheres and what is the amp grounded to, also your power wire could be sitting on something cause it to short blowing the fuse which is most likely the cause. Next step are the fuses on the amp blowing it could be the speaker wires grounded. Double check all your wiring to make sure nothing is touching.
Cardomain
Old 12-19-2006, 11:50 PM
well the amp is in the trunk and i grounded it to the bolt thats holding the turnk latch..the fuse just blows everytime i turn on the car..i can hear it blow when i turn it on....i dont kno what causes the fuse to blow..
Old 12-20-2006, 12:06 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
fuses blow because you trying to pull too much current through it
Old 12-20-2006, 12:13 PM
should i just get a new power cable ?
Old 12-20-2006, 12:44 PM
bjboertje's Avatar
bjboertje bjboertje is offline
how about we keep this in the thread you started and don't hijack other's threads with the exact same question you asked before.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Rainbow CMX 265 front stage
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
