Old 12-15-2006, 05:46 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
Recomendations of clutch/flywheel combo for my SL.
I had a new OEM clutch installed 8 months and 10,000 miles ago (flywheel was also resurfaced) on my '93, and it's already started to slip: noticabely in higher gears, especially when downshifting 5->4, or 4->3. I drive in a very sober fashion, so I'm not sure why the wear was so quick!
Anyway. I'm looking into buying a clutch kit, and a new flywheel while I'm at it (at 150K miles, I think it's time for a new one). Can anyone recommend a brand that is a stage above OEM? I am looking for a streetable clutch that is a little better than OEM, but nothing on the top end. Something a tad more grippy than a stocker. I was looking at 3sx's SPEC clutches, but I read some negative on-line reviews about their fitment and customer service. ACT? Exedy?
The daily driver. The weekend cruiser. The lazy shop hog.
Old 12-15-2006, 10:44 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Re: Recomendations of clutch/flywheel combo for my SL.
I'll tell you exactly why it wore so fast...you got your flywheel resurfaced. If it's not done PERFECTLY to spec, your clutch will burn out quick. And 9 shops out of 10, have no specs and just machine the steps on the flywheel down to a rough estimate of what they machined the face. Happened to me twice.
A new flywheel costs about $50 at Autozone, probably cheaper at Advanced Auto Parts. I would go with that, and an OEM clutch kit($80 at dealer). Unless you're twin-turbo'ing your SL, you don't need anything special.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 12-16-2006, 12:33 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
good stuff to know. can you tell us the exact specs to 2-step the flywheel? its probably in the service manual. i'll take a look there. just curious if you knew it off the top of ur head.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 12-16-2006, 03:15 AM
Shpyder's Avatar
Moderate moderator
Originally Posted by Linebckr49
good stuff to know.
I didn't know that either. I guess I'll just go OEM and get a new flywheel.
Twizted_3KGT: The Autozone flywheel...is it OEM spec or better?
Old 12-16-2006, 09:39 PM
Yes the Autozone flywheel is the same as OEM.
As for the spec, I did a lot of searching before, and I think I remember finding it, but the only thing I have bookmarked is this http://www.roadraceengineering.com/c...ywheeltech.htm which is for Eclipses, but it's got some good information on why it needs to be perfect and how to measure it.
Old 12-17-2006, 01:05 PM
Shpyder's Avatar
Moderate moderator
Thanks for all the info. Autozone, I cometh to purchase from thee.
