Old 12-15-2006, 12:50 PM
2000CAYukon 2000CAYukon is offline
Driveline feels like it is binding
1990 K1500 Pickup 5.7 4L60 125K Miles Original Owner
After a 10 miles freeway drive, I was stopped at a light. When the light turned green, it felt like something was binding in the driveline. I really don't know where or what. It was hard to tell but if felt like the rear end or transfer case. I could not pull over (no room) and it went away after 100 ft or so.
I nursed it home after work and jacked up the rear of the truck. Engine off, tranny in neutral and spinning the rear tires I could hear a noise coming from the Transfer Case. Almost a low sqweak. It was not grinding and the front end was not off the ground. I checked the fluid and the level was fine. Drained it and it did not look good. A dark red instead of light pink. Looking at my maintenace records, it looks like I did not change it for 40 or 45 K miles. I know that this is too long. I also dropped the tail housing and the snap ring looked fine so that is not the issue or problem. The U-joints are original and both of them felt fine while I had the drive shaft out.
Should I put use Auto Trak Fluid now or just replace it with the usual Dextron III?
Could the old fluid cause this?
I am still not sure that this is my issue or not. If anyone has any advice on how to trouble shoot or diagnose this, I sure would appreciate it.
//2000CAYukon
Old 12-15-2006, 03:19 PM
maxwedge maxwedge is offline
A990 racer
Re: Driveline feels like it is binding
Well, I wouldn't use autotrak if it is not recommended stay with the Dex111. I once had a similar symptom in my 92 s-10 Blazer, it was the G 80 locking diff binding, but you can probably tell the difference, if you have he Eaton locker, pull the cover and take a look, they were troublesome. You may have to wait till it gets worse to really be sure.
Old 12-15-2006, 04:26 PM
I do have the G80 option on my Z71 and I think that is a possibility. I plan to replace the fluid along with a new bottle of posi lube.
I should note that this problem actually happened twice. The first time it happened a worker was blowing leaves under my truck. I mean a lot of leaves. So when I pulled out of the parking space, I lost traction and noticed the binding. I pulled over and looked under the truck but did not notice anything. A few days later it happened coming off the freeway.
In your case, did you have to replace the locker?
//2000CAYukon
Old 12-15-2006, 06:43 PM
A990 racer
Forget the posi lube, not recommended for the Eaton locker. This is not a full time limited slip, just the regular stuff or synthethic will do. Your addt'l info definitely points to the diff.
Old 12-15-2006, 06:52 PM
Thanks maxwedge, I was not sure if I needed the lube or not. My car also has a posi and it requries the lube (I think it has an Auburn locker).
I was going to review the manuals before doing anything.
Do you think a fluid change can help or is the locker probably shot? Is the Eaton rebuildable or do I have to replace it?
Thanks again maxwedge!
//2000CAYukon
Old 12-16-2006, 06:58 AM
69Charger 69Charger is offline
Send a message via MSN to 69Charger
You require the additive in ANY and ALL clutch type t-cases and differentials..
Also, it sounds to me like you have spit a planetary set or something in the back of the transmission.. I had a problem with the overruning clutch drum in a 700R4 a long time ago, did the exact same thing
Mark Mcknight
Elmvale Truck & 4x4
(705)-715-7867
Elmvale, Ontario
87 Mustang GT, 5.0L 5 spd, MSD ignition, BBK tubes, flowmasters, tri-ax shifter, 4.10 gears
69 Charger SE, stroked & poked 383,727 over 550rwhp
86 Chevy 2500 4x4 Plow truck, 350/TH400, 8ft fisher plow
Old 12-16-2006, 11:16 AM
Well that does sound good. It is hard to tell where it is binding.
Is there anyway to know if it is the tranny without tearing it down?
Thanks,
2000CAYukon
Old 12-16-2006, 12:11 PM
It really is hard to isolate a problem like that.. I'd start by disconnecting driveshafts and spinning wheels... making sure gears aren't binding..I guess you basically did that already.. Have you tried turning the front driveshaft with it in 4wd with the engine off so the front diff is disengaged? I don't suppose its a chain or maybe the pump?
When mine blew up it took almost a year of driving for it blow completely and stop working..
When your driving down the road in overdrive and you downshift it to 2nd manually, does it coast or does it engine brake? Or does it chatter?
Mark Mcknight
Elmvale Truck & 4x4
(705)-715-7867
Elmvale, Ontario
Old 12-18-2006, 01:37 PM
I did not try that. But will give that a try if the problem comes back.
It shifted into 2nd and slowed down (engine brake). The binding has only happened twice. The only tranny issue I am having currently is when it downshifts from 2nd to 1st when the tranny is cold. Twice this has happened and when the downshift was suppose to happen it acted like it was in neutral. It does not happen when the tranny is warm.
2 years ago, it had a weak shift into 3rd or 4th. I decided to add billet servos and a larger boost valve (.471). That helped and I was going to pull the valve body at some point and maybe install a Transgo kit. Just never got the time. Maybe I will wait til it blows up.
I changed the fluid in both diffs and the transfer case on Saturday. I did find some metal shavings in the rear diff. 2 or 3 pieces that were maybe a 1/16 inch by 1/8 inch but not very thick. I could not see where they came from.
I have driven the truck and the problem (binding) has not reoccured yet. Guess I will drive it until it happens again.
//2000CAYukon
Old 12-18-2006, 04:00 PM
A990 racer
Lightbulb Re: Driveline feels like it is binding
Read any GM manual on the Eaton G80 locker, no additive is required.
Old 12-18-2006, 05:36 PM
twistedtech twistedtech is offline
Talk about a freekin helet fire.....Is it not suppose to have the proper oil and I'll be damned if I can remember it right now.
If it ain't broke.......screw with it till it is.
Even at a Mensa convention,
Someone's the dumbest person in the room.
Old 12-18-2006, 06:33 PM
A990 racer
75-90 diff oil or synthetic, the posi additive of old is not required with this type diff, it is not a limited slip/full time posi. Lets put this to sleep.
Old 12-18-2006, 07:42 PM
I agree. I already filled both diffs with 80-90 gear oil since that is what my manuals call for.
I am more concerned that I found some metal shavings on the diff magnet. 2 or 3 pieces that were maybe a 1/16 inch by 1/8 inch but not very thick. I could not see where they came from.
Still waiting for it to happen again. I have owned this truck for 17 years and 125K miles. I will probably drive it into the ground.
//2000CAYukon
Old 12-19-2006, 07:04 PM
I'm checking out mitchell on demand to see what it says for you
Mark Mcknight
Elmvale Truck & 4x4
(705)-715-7867
Elmvale, Ontario
